Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I have get the docker of orin drive os sdk 6.0.8.1, and compiling the kernel (kernel 5.15) follow the step:
There were error when I Execute Build-FS with the preceding configuration to rebuild the filesystem as follow:
there was no /drive/drive-linux/kernel/preempt_rt/modules/5.15.98-rt-tegra/extra/nvgpu.ko in the build modules, I can’t find the nvgpu.ko in anywhere, did the nvgpu.ko need build through other patch?
apart form this error , the modules file int he following directory cannot be found as well:
/drive/drive-linux/kernel/preempt_rt/modules/5.15.98-rt-tegra/updates/dkms the dkms directory also can’t be found in the build modules , did the dkms also need to build by other?
thanks
