Installing Drive OS 6.0 from sdkmanager is giving an error?
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
Error:
16:44:16 INFO: DRIVE OS SDK - target_image: exec_command: /tmp/tmp_NV_DRIVE_MASTER_DEB_SDK_COMP.sh
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-common-build-fs-17.1.11-67787297
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-common-copytarget-1.4.9-e6d22352
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-foundation-gcc-bootlin-gcc9.3-aarch64–glibc–stable-2022.03-1
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-foundation-gcc-bootlin-gcc9.3-armv5-eabi–glibc–stable-2020.08-1
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-foundation-gcc-bootlin-gcc9.3-armv7-eabihf–glibc–stable-2020.08-1
16:44:22 ERROR: DRIVE OS SDK - target_image: dpkg-query: no packages found matching nv-driveos-foundation-toolchains-9.3.0
16:44:22 INFO: DRIVE OS SDK - target_image: [ Package PreInstall Finished Successfully ]
Dear @jackbwang,
Could you share ~/.nvsdkm/logs and ~/.nvsdkm/sdkm*.log
Attached is the Log
SDKM_logs_DRIVE_OS_6.0.6_SDK_Linux_for_DRIVE_AGX_Orin_DevKits_2023-04-18_10-38-45.zip (176.2 KB)
As we know you have other support channels available, I suggest reporting this issue there. It seems that the issue may be related to an apt mess-up, so you could try installing with a docker container (see Install DRIVE OS Linux Docker Containers from NGC | NVIDIA Docs).
Thanks, I will stop this thread
