Software Version
[0] DRIVE OS 6.0.6
Target Operating System
Linux
Hardware Platform
other
SDK Manager Version
2.2.0
Host Machine Version
Issue Description
not able to flash using SDK manager( I need help with SDK manager only not Docker)
Error String
FileNotFoundError: [Errno 2] No such file or directory: ‘/home/user/Downloads/DRIVE_OS_6.0.6_SDK_Linux_DRIVE_AGX_ORIN_DEVKITS/DRIVEOS//drive-linux/filesystem/targetfs/usr/bin/’
Full Matter:-
Hello NVIDIA Support Team,
I am working with the NVIDIA DRIVE AGX Orin board and attempting to flash it using the SDK Manager (please note that Docker is not an option in my setup).
However, I am encountering the following error during the flashing process:
The directory mentioned in the error does exist on my system, and it has full read-write-execute permissions. Another related issue is that the script fails while copying qemu-aarch64-static from targetfs/usr/bin/. I have verified that this file exists on the host system as well. Even after manually copying it and ensuring full permissions, the SDK Manager continues to throw the same error.
I have also tested the process on three different host machines, all resulting in the same error.
I have attached the relevant log files for your review. Kindly help me resolve this issue using SDK Manager only, without Docker.
Note :- why there has not been a SDK managers for latest versions(6.0.8 or 6.0.10) ?
Regards
Ravi teja
Logs
NV_DRIVE_FLASH_DRIVE_COMP.log (10.3 KB)
