I am using OmniIsaacGymEnv (GitHub - NVIDIA-Omniverse/OmniIsaacGymEnvs: Reinforcement Learning Environments for Omniverse Isaac Gym), and I get error when using custom visualization markers.
Essentially, I create a VisualPin following the same template as the VisualSphere or other USDGeom shapes.
I also create FixedPin, and DynamicPin. Then I use this pin instead of the DynamicSphere in tasks such as the Crazyflie, however, when I do that the simulation crashes. The interesting thing is that it didn’t crash with the previous version of Omniverse (2022.2.0).
I think the issue comes from the fact that I base my marker out of an XformPrim, but I could also do something completely wrong. I have attached the crashlogs and the code I use.
Thanks in advance,
Regards,
Antoine
Here is the the crash logs:
PxgCudaDeviceMemoryAllocator fail to allocate memory 268435456 bytes!! Result = 2
PxgCudaDeviceMemoryAllocator fail to allocate memory 67108864 bytes!! Result = 2
2023-04-20 15:05:14 [21,747ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuEventRecord failed with error 700
, FILE /buildAgent/work/16dcef52b68a730f/source/gpucommon/include/PxgCudaUtils.h, LINE 53
2023-04-20 15:05:14 [21,747ms] [Error] [omni.physx.plugin] Cuda context manager error, simulation will be stopped and new cuda context manager will be created.
2023-04-20 15:05:14 [21,748ms] [Error] [omni.physx.plugin] PhysX error: SynchronizeStreams cuStreamWaitEvent failed with error 700
, FILE /buildAgent/work/16dcef52b68a730f/source/gpucommon/include/PxgCudaUtils.h, LINE 59
2023-04-20 15:05:14 [21,748ms] [Error] [omni.physx.plugin] Cuda context manager error, simulation will be stopped and new cuda context manager will be created.
2023-04-20 15:05:14 [21,748ms] [Error] [omni.physx.plugin] PhysX error: memcpy failed fail!
700, FILE /buildAgent/work/16dcef52b68a730f/source/gpunarrowphase/src/PxgNarrowphaseCore.cpp, LINE 2077
A LOT OF CUDA ERRORS
Error executing job with overrides: ['task=Crazyflie', 'num_envs=512', 'headless=False', 'max_iterations=1000', 'task.sim.dt=0.02']
File "scripts/rlgames_train.py", line 115, in parse_hydra_configs
task = initialize_task(cfg_dict, env)
File "/home/antoine/Documents/Orbitals/Omniverse/omniisaacgymenvs/utils/task_util.py", line 90, in initialize_task
env.set_task(task=task, sim_params=sim_config.get_physics_params(), backend="torch", init_sim=init_sim)
File "/home/antoine/Documents/Orbitals/Omniverse/omniisaacgymenvs/envs/vec_env_rlgames.py", line 51, in set_task
super().set_task(task, backend, sim_params, init_sim)
File "/home/antoine/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.gym/omni/isaac/gym/vec_env/vec_env_base.py", line 94, in set_task
self._world.reset()
File "/home/antoine/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/world/world.py", line 281, in reset
SimulationContext.reset(self, soft=soft)
File "/home/antoine/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 408, in reset
SimulationContext.initialize_physics(self)
File "/home/antoine/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 388, in initialize_physics
self._physics_sim_view = omni.physics.tensors.create_simulation_view(self.backend)
File "/home/antoine/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/extsPhysics/omni.physics.tensors-104.2.4-5.1/omni/physics/tensors/impl/api.py", line 12, in create_simulation_view
raise Exception("Failed to create simulation view backend")
Exception: Failed to create simulation view backend
Example of the new get_target function in the Craziefly task that leads to a crash.
def get_target(self):
radius = 0.2
color = torch.tensor([1, 0, 0])
ball = DynamicPin(
prim_path=self.default_zero_env_path + "/ball",
translation=self._ball_position,
name="target_0",
ball_radius=0.125,
poll_radius=0.025,
poll_length=2.0,
color=color)
self._sim_config.apply_articulation_settings("ball", get_prim_at_path(ball.prim_path),
self._sim_config.parse_actor_config("ball"))
The code of the “DynamicPin”:
from typing import Optional, Sequence
import numpy as np
from omni.isaac.core.materials.visual_material import VisualMaterial
from omni.isaac.core.prims.rigid_prim import RigidPrim
from omni.isaac.core.prims.xform_prim import XFormPrim
from omni.isaac.core.prims.geometry_prim import GeometryPrim
from omni.isaac.core.materials import PreviewSurface
from omni.isaac.core.materials import PhysicsMaterial
from omni.isaac.core.utils.string import find_unique_string_name
from omni.isaac.core.utils.prims import get_prim_at_path, is_prim_path_valid
from omniisaacgymenvs.utils.shape_utils import Pin
class FixedPin(VisualPin):
"""_summary_
Args:
prim_path (str): _description_
name (str, optional): _description_. Defaults to "fixed_sphere".
position (Optional[np.ndarray], optional): _description_. Defaults to None.
translation (Optional[np.ndarray], optional): _description_. Defaults to None.
orientation (Optional[np.ndarray], optional): _description_. Defaults to None.
scale (Optional[np.ndarray], optional): _description_. Defaults to None.
visible (Optional[bool], optional): _description_. Defaults to None.
color (Optional[np.ndarray], optional): _description_. Defaults to None.
radius (Optional[np.ndarray], optional): _description_. Defaults to None.
visual_material (Optional[VisualMaterial], optional): _description_. Defaults to None.
physics_material (Optional[PhysicsMaterial], optional): _description_. Defaults to None.
def __init__(
self,
prim_path: str,
name: str = "fixed_arrow",
position: Optional[np.ndarray] = None,
translation: Optional[np.ndarray] = None,
orientation: Optional[np.ndarray] = None,
scale: Optional[np.ndarray] = None,
visible: Optional[bool] = None,
color: Optional[np.ndarray] = None,
ball_radius: Optional[float] = None,
poll_radius: Optional[float] = None,
poll_length: Optional[float] = None,
visual_material: Optional[VisualMaterial] = None,
physics_material: Optional[PhysicsMaterial] = None,
) -> None:
if not is_prim_path_valid(prim_path):
# set default values if no physics material given
if physics_material is None:
static_friction = 0.2
dynamic_friction = 1.0
restitution = 0.0
physics_material_path = find_unique_string_name(
initial_name="/World/Physics_Materials/physics_material",
is_unique_fn=lambda x: not is_prim_path_valid(x),
physics_material = PhysicsMaterial(
prim_path=physics_material_path,
dynamic_friction=dynamic_friction,
static_friction=static_friction,
restitution=restitution,
VisualPin.__init__(
self,
prim_path=prim_path,
name=name,
position=position,
translation=translation,
orientation=orientation,
scale=scale,
visible=visible,
color=color,
ball_radius = ball_radius,
poll_radius = poll_radius,
poll_length = poll_length,
visual_material=visual_material,
#XFormPrim.set_collision_enabled(self, True)
#if physics_material is not None:
# FixedArrow.apply_physics_material(self, physics_material)
return
class DynamicPin(RigidPrim, FixedPin):
"""_summary_
Args:
name (str, optional): _description_. Defaults to "dynamic_sphere".
mass (Optional[float], optional): _description_. Defaults to None.
density (Optional[float], optional): _description_. Defaults to None.
linear_velocity (Optional[Sequence[float]], optional): _description_. Defaults to None.
angular_velocity (Optional[Sequence[float]], optional): _description_. Defaults to None.
def __init__(
self,
prim_path: str,
name: str = "dynamic_sphere",
mass: Optional[float] = None,
density: Optional[float] = None,
linear_velocity: Optional[Sequence[float]] = None,
angular_velocity: Optional[Sequence[float]] = None,
) -> None:
if mass is None:
mass = 0.02
FixedPin.__init__(
self,
name=name,
position=position,
scale=scale,
visible=visible,
color=color,
physics_material=physics_material,
RigidPrim.__init__(
self,
name=name,
position=position,
scale=scale,
visible=visible,
mass=mass,
density=density,
linear_velocity=linear_velocity,
angular_velocity=angular_velocity,
from pxr import UsdGeom, Gf
from omni.isaac.core.utils.stage import get_current_stage
def setXformOp(prim, value, property):
xform = UsdGeom.Xformable(prim)
op = None
for xformOp in xform.GetOrderedXformOps():
if xformOp.GetOpType() == property:
op = xformOp
if op:
xform_op = op
else:
xform_op = xform.AddXformOp(property, UsdGeom.XformOp.PrecisionDouble, "")
xform_op.Set(value)
def setScale(prim, value):
setXformOp(prim, value, UsdGeom.XformOp.TypeScale)
def setTranslate(prim, value):
setXformOp(prim, value, UsdGeom.XformOp.TypeTranslate)
def setRotateXYZ(prim, value):
setXformOp(prim, value, UsdGeom.XformOp.TypeRotateXYZ)
def setOrient(prim, value):
setXformOp(prim, value, UsdGeom.XformOp.TypeOrient)
def setTransform(prim, value: Gf.Matrix4d):
setXformOp(prim, value, UsdGeom.XformOp.TypeTransform)
class Pin:
def __init__(self, prim_path, ball_radius, poll_radius, poll_length):
if ball_radius is None:
ball_radius = 0.1
if poll_radius is None:
poll_radius = 0.02
if poll_length is None:
poll_length = 2
self.ball_geom = None
self.poll_geom = None
ball_prim_path = prim_path+"/ball"
if is_prim_path_valid(ball_prim_path):
ball_prim = get_prim_at_path(ball_prim_path)
if not ball_prim.IsA(UsdGeom.Sphere):
raise Exception("The prim at path {} cannot be parsed as a pin object".format(ball_prim_path))
self.ball_geom = UsdGeom.Sphere(ball_prim)
else:
self.ball_geom = UsdGeom.Sphere.Define(get_current_stage(), ball_prim_path)
poll_prim_path = prim_path+"/poll"
if is_prim_path_valid(poll_prim_path):
poll_prim = get_prim_at_path(poll_prim_path)
if not poll_prim.IsA(UsdGeom.Cylinder):
raise Exception("The prim at path {} cannot be parsed as a pin object".format(poll_prim_path))
self.poll_geom = UsdGeom.Cylinder(poll_prim)
else:
self.poll_geom = UsdGeom.Cylinder.Define(get_current_stage(), poll_prim_path)
setTranslate(poll_prim, Gf.Vec3d([0, 0, -poll_length/2]))
setOrient(poll_prim, Gf.Quatd(0,Gf.Vec3d([0, 0, 0])))
setScale(poll_prim, Gf.Vec3d([1, 1, 1]))
setTranslate(ball_prim, Gf.Vec3d([0, 0, 0]))
setOrient(ball_prim, Gf.Quatd(1,Gf.Vec3d([0, 0, 0])))
setScale(ball_prim, Gf.Vec3d([1, 1, 1]))
def updateExtent(self):
radius = self.get_ball_radius()
self.ball_geom.GetExtentAttr().Set(
[Gf.Vec3f([-radius, -radius, -radius]), Gf.Vec3f([radius, radius, radius])]
radius = self.get_poll_radius()
height = self.get_poll_length()
self.poll_geom.GetExtentAttr().Set(
[Gf.Vec3f([-radius, -radius, -height / 2.0]), Gf.Vec3f([radius, radius, height / 2.0])]
def set_ball_radius(self, radius: float) -> None:
"""[summary]
Args:
radius (float): [description]
self.ball_geom.GetRadiusAttr().Set(radius)
return
def get_ball_radius(self) -> float:
"""[summary]
Returns:
float: [description]
return self.ball_geom.GetRadiusAttr().Get()
def set_poll_radius(self, radius: float) -> None:
"""[summary]
Args:
self.poll_geom.GetRadiusAttr().Set(radius)
return
def get_poll_radius(self) -> float:
"""[summary]
Returns:
return self.poll_geom.GetRadiusAttr().Get()
def set_poll_length(self, radius: float) -> None:
"""[summary]
Args:
self.poll_geom.GetHeightAttr().Set(radius)
return
def get_poll_length(self) -> float:
"""[summary]
Returns:
return self.poll_geom.GetHeightAttr().Get()
