Critical error message from using nvv4l2decoder and nvv4l2h264enc where the message is "gst_mini_object_unref: assertion 'mini_object != NULL' failed"
Jetson
• DeepStream Version
6.0
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
• TensorRT Version
8.0.1.6-1+cuda10.2
questions or bug
I’m trying to do transcoding from h264 to h264 with different parameters, so I connect both nvv4l2decoder
and nvv4l2h264enc directly.
The major component source code could be like this
source->decoder = gst_element_factory_make (“nvv4l2decoder”, elem_name);
source->encoder = gst_element_factory_make (“nvv4l2h264enc”, elem_name);
parser2 = gst_element_factory_make (“h264parse”, elem_name);
gst_bin_add_many (GST_BIN (source->source_bin), source->src_elem,
source->decoder,
source->encoder,
source->parser2,
source->mux,
source->filesink,
NULL);
gst_element_link_many(source->decoder, source->encoder, source->parser2, source->mux, source->filesink, NULL);
And the src_element is using rtspsrc with call back “select-stream” to link decoder with parser element.
The console output will be
(edge-engine-intrusion:13377): GStreamer-CRITICAL **: 03:04:41.981: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
(edge-engine-intrusion:13377): GStreamer-CRITICAL **: 03:04:41.983: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteBlockCreate : Block : BlockType = 261
Decodebin linked to videorate
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Create a source info instance 1, event timestamp -1, event seq 569
H264: Profile = 66, Level = 0
please refer to this transcode command: gst-launch-1.0 filesrc location=sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=I420’ ! nvv4l2h264enc bitrate=1000000 ! filesink location=bp.264
I will try to survey how to add those components between decoder & encoder programmatically, maybe use nvvideoconvert and capsfilter.
But I’m curious why we need the nvvideoconvert for it. I think they can naturally connect together.
yes ,on jetson, there is no need nvconvert, please refer to gst-launch-1.0 filesrc location=sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvv4l2h264enc bitrate=1000000 ! filesink location=bp.264, Gst-nvvideo4linux2 — DeepStream 6.1.1 Release documentation
