Hello, what resources are there to get PyQt6 running on the Jetson Nano? When attempting to install PyQt6 on Python 3.7.9 I get the following error:
Defaulting to user installation because normal site-packages is not writeable
Collecting PyQt6==6.4.2
Using cached PyQt6-6.4.2.tar.gz (1.0 MB)
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … error
error: subprocess-exited-with-error
× Preparing metadata (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [17 lines of output]
Querying qmake about your Qt installation…
pyproject.toml: line 7: using ‘[tool.sip.metadata]’ to specify the project metadata is deprecated and will be removed in SIP v7.0.0, use ‘[project]’ instead
File “/home/team11/.local/lib/python3.7/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 353, in
main()
File “/home/team11/.local/lib/python3.7/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 335, in main
json_out[‘return_val’] = hook(**hook_input[‘kwargs’])
File “/home/team11/.local/lib/python3.7/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 152, in prepare_metadata_for_build_wheel
whl_basename = backend.build_wheel(metadata_directory, config_settings)
File “/tmp/pip-build-env-6f00pipt/overlay/lib/python3.7/site-packages/sipbuild/api.py”, line 47, in build_wheel
arguments=_convert_config_settings(config_settings))
File “/tmp/pip-build-env-6f00pipt/overlay/lib/python3.7/site-packages/sipbuild/abstract_project.py”, line 92, in bootstrap
project.setup(pyproject, tool, tool_description)
File “/tmp/pip-build-env-6f00pipt/overlay/lib/python3.7/site-packages/sipbuild/project.py”, line 603, in setup
self.update(tool)
File “project.py”, line 164, in update
sipbuild.exceptions.UserException
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Attempts at diagnosing this issue with sites like: Ubuntu – Details of package qt6-base-dev in jammy
have not worked.
