I’m trying to get a QT creator designed GUI working on Nano with a python code. but it’s complaining
(python3.6:18572): GLib-GObject-WARNING **: 19:25:03.988: cannot register existing type 'GdkDisplayManager' (python3.6:18572): GLib-CRITICAL **: 19:25:03.988: g_once_init_leave: assertion 'result != 0' failed (python3.6:18572): GLib-GObject-CRITICAL **: 19:25:03.988: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed (python3.6:18572): GLib-GObject-WARNING **: 19:25:03.988: invalid (NULL) pointer instance (python3.6:18572): GLib-GObject-CRITICAL **: 19:25:03.988: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed (python3.6:18572): GLib-GObject-WARNING **: 19:25:03.988: invalid (NULL) pointer instance (python3.6:18572): GLib-GObject-CRITICAL **: 19:25:03.988: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed (python3.6:18572): GLib-GObject-WARNING **: 19:25:04.001: cannot register existing type 'GdkDisplay' (python3.6:18572): GLib-CRITICAL **: 19:25:04.001: g_once_init_leave: assertion 'result != 0' failed (python3.6:18572): GLib-GObject-CRITICAL **: 19:25:04.001: g_type_register_static: assertion 'parent_type > 0' failed (python3.6:18572): GLib-CRITICAL **: 19:25:04.001: g_once_init_leave: assertion 'result != 0' failed (python3.6:18572): GLib-GObject-CRITICAL **: 19:25:04.001: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
It might be the problem with gtk? but i have no idea how to fix this.
