I have an error running python code containing opencv and pyqt5. pyqt5’s ui turns gray when the program runs and an error is reported. The details are as follows:
(python3:7640): GLib-GObject-WARNING **: 21:55:41.647: cannot register existing type ‘GdkDisplayManager’
(python3:7640): GLib-CRITICAL **: 21:55:41.647: g_once_init_leave: assertion ‘result != 0’ failed
(python3:7640): GLib-GObject-CRITICAL **: 21:55:41.647: g_object_new_with_properties: assertion ‘G_TYPE_IS_OBJECT (object_type)’ failed
(python3:7640): GLib-GObject-WARNING **: 21:55:41.647: invalid (NULL) pointer instance
(python3:7640): GLib-GObject-CRITICAL **: 21:55:41.648: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(python3:7640): GLib-GObject-WARNING **: 21:55:41.648: invalid (NULL) pointer instance
(python3:7640): GLib-GObject-WARNING **: 21:55:41.743: cannot register existing type ‘GdkDisplay’
(python3:7640): GLib-CRITICAL **: 21:55:41.743: g_once_init_leave: assertion ‘result != 0’ failed
(python3:7640): GLib-GObject-CRITICAL **: 21:55:41.744: g_type_register_static: assertion ‘parent_type > 0’ failed
(python3:7640): GLib-CRITICAL **: 21:55:41.744: g_once_init_leave: assertion ‘result != 0’ failed
(python3:7640): GLib-GObject-CRITICAL **: 21:55:41.744: g_object_new_with_properties: assertion ‘G_TYPE_IS_OBJECT (object_type)’ failed
my .bashrc:
export OPENBLAS_CORETYPE=ARMV8
SWIG_PATH=/urs/local/share/swig/3.0.12
PATH=$PATH:$SWIG_PATH
export PYTHONPATH=$PYTHONPATH:/usr/local/lib:/usr/local/lib/python3.6/pyrealsense2
export PATH=/usr/local/cuda/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH
export DISPLAY=:0.0
my .profile:
export QT_QPA_PLATFORMTHEME=gtk2
The problem was never solved.
