我们使用ORIN NX 8G,jetson版本为35.3.1,MAX9286进行四路摄像头的调试,在A底板上可以出图,更换到B底板上后,进行了设备树的匹配,发现无法出图,日志如下,请问我们能从日志获取到什么信息么?
[ 189.458747] max9286 i2c[0x15]=0x9b
[ 191.963289] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 191.972422] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 191.982880] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 191.990707] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 192.001375] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 192.009088] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 3
[ 192.020126] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 192.030086] max9286 i2c[0x15]=0x13
[ 192.033869] bwmgr API not supported
[ 192.042906] isx019 7-001d: isx019_power_off:
