cublas_cublasDgetrsBatched_problem
I couldn’t find any examples of cublasDgetrsBatched.
when I used cublasDgetrsBatched, the return value of my program is not 0, is my parameter wrong?
A_matrix : batchSize * 64(8 * 8)
B_matrix: batchSize * 8(8 * 1)
A_matrix and B_matrix both 2_dimension
cublasDgetrsBatched(handle, CUBLAS_OP_N, m, 1, A_matrix, lda, NULL, B_matrix, ldb, d_info, batchSize);
here is the info of cublasDgetrsBatched, actually I don’t understand the meaning of n,nrhs , lda, ldb;
Param. Memory In/out Meaning
handle input handle to the cuBLAS library context.
trans input operation op(A) that is non- or (conj.) transpose.
n input number of rows and columns of Aarray[i].
nrhs input number of columns of Barray[i].
Aarray device input array of pointers to array, with each array of dim. n x n with lda>=max(1,n).
lda input leading dimension of two-dimensional array used to store each matrix Aarray[i].
devIpiv device input array of size n x batchSize that contains the pivoting sequence of each factorization of Aarray[i] stored in a linear fashion. If devIpiv is nil, pivoting for all Aarray[i] is ignored.
Barray device input/output array of pointers to array, with each array of dim. n x nrhs with ldb>=max(1,n). Matrices Barray[i] should not overlap; otherwise, undefined behavior is expected.
ldb input leading dimension of two-dimensional array used to store each solution matrix Barray[i].
info host output If info=0, the execution is successful.
If info = -j, the j-th parameter had an illegal value.|
|batchSize||input|number of pointers contained in A|
Can you look at the potrfBatched example? It includes potrsBatched, which is similar to getrsBatched.
thanks for your reply, I tested the portBatched example, and then I change the API to getrfBatched and getrsBatched, I got the same problem, program exited , the code -1073741819. I’m very confused.
here is the code
int main(int argc, char* argv[x]) {
    cusolverDnHandle_t cusolverH = NULL;
    cublasHandle_t handle = NULL;
    cudaStream_t stream = NULL;
    const cublasFillMode_t uplo = CUBLAS_FILL_MODE_LOWER;
    const int batchSize = 2;
    const int nrhs = 1;
    const int m = 3;
    const int lda = m;
    const int ldb = m;
     *      | 1     2     3 |
     * A0 = | 2     5     5 | = L0 * L0**T
     *      | 3     5    12 |
     *            | 1.0000         0         0 |
     * where L0 = | 2.0000    1.0000         0 |
     *            | 3.0000   -1.0000    1.4142 |
     *      | 1     2     3 |
     * A1 = | 2     4     5 | is not s.p.d., failed at row 2
     *      | 3     5    12 |
    const std::vector<double> A0 = { 1.0, 2.0, 3.0, 2.0, 5.0, 5.0, 3.0, 5.0, 12.0 };
    const std::vector<double> A1 = { 1.0, 2.0, 3.0, 2.0, 4.0, 5.0, 3.0, 5.0, 12.0 };
    const std::vector<double> B0 = { 1.0, 1.0, 1.0 };
    std::vector<double> X0(m, 0);             /* X0 = A0\B0 */
    std::vector<int> infoArray(batchSize, 0); /* host copy of error info */
    std::vector<double> L0(lda * m); /* cholesky factor of A0 */
    std::vector<double*> Aarray(batchSize, nullptr);
    std::vector<double*> Barray(batchSize, nullptr);
    double** d_Aarray = nullptr;
    double** d_Barray = nullptr;
    int* d_infoArray = nullptr;
    std::printf("A0 = (matlab base-1)\n");
    print_matrix(m, m, A0.data(), lda);
    std::printf("=====\n");
    std::printf("A1 = (matlab base-1)\n");
    print_matrix(m, m, A1.data(), lda);
    std::printf("B0 = (matlab base-1)\n");
    print_matrix(m, 1, B0.data(), ldb);
    /* step 1: create cusolver handle, bind a stream */
    CUSOLVER_CHECK(cusolverDnCreate(&cusolverH));
    CUBLAS_CHECK(cublasCreate(&handle));
    CUDA_CHECK(cudaStreamCreateWithFlags(&stream, cudaStreamNonBlocking));
    CUSOLVER_CHECK(cusolverDnSetStream(cusolverH, stream));
    CUBLAS_CHECK(cublasSetStream(handle, stream));
    /* step 2: copy A to device */
    for (int j = 0; j < batchSize; j++) {
        CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&Aarray[j]), sizeof(double) * lda * m));
        CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&Barray[j]), sizeof(double) * ldb * nrhs));
    CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&d_infoArray), sizeof(int) * infoArray.size()));
    CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&d_Aarray), sizeof(double*) * Aarray.size()));
    CUDA_CHECK(cudaMalloc(reinterpret_cast<void**>(&d_Barray), sizeof(double*) * Barray.size()));
    CUDA_CHECK(cudaMemcpyAsync(Aarray[0], A0.data(), sizeof(double) * A0.size(),
        cudaMemcpyHostToDevice, stream));
    CUDA_CHECK(cudaMemcpyAsync(Aarray[1], A1.data(), sizeof(double) * A1.size(),
    CUDA_CHECK(
        cudaMemcpyAsync(Barray[0], B0.data(), sizeof(double) * B0.size(), cudaMemcpyHostToDevice, stream));
    CUDA_CHECK(
        cudaMemcpyAsync(Barray[1], B0.data(), sizeof(double) * B0.size(), cudaMemcpyHostToDevice, stream));
    CUDA_CHECK(cudaMemcpyAsync(d_Aarray, Aarray.data(), sizeof(double) * Aarray.size(),
    CUDA_CHECK(cudaMemcpyAsync(d_Barray, Barray.data(), sizeof(double) * Barray.size(),
    /* step 3: Cholesky factorization */
    //CUSOLVER_CHECK(
        //cusolverDnDpotrfBatched(cusolverH, uplo, m, d_Aarray, lda, d_infoArray, batchSize));
    CUBLAS_CHECK(cublasDgetrfBatched(handle, m, d_Aarray, lda, NULL, d_infoArray, batchSize));
    CUDA_CHECK(cudaMemcpyAsync(infoArray.data(), d_infoArray, sizeof(int) * infoArray.size(),
        cudaMemcpyDeviceToHost, stream));
    CUDA_CHECK(cudaMemcpyAsync(L0.data(), Aarray[0], sizeof(double) * lda * m,
    CUDA_CHECK(cudaStreamSynchronize(stream));
        std::printf("info[%d] = %d\n", j, infoArray[j]);
    assert(0 == infoArray[0]);
    /* A1 is singular */
    assert(2 == infoArray[1]);
    std::printf("L = (matlab base-1), upper triangle is don't care \n");
    print_matrix(m, m, L0.data(), lda);
     * step 4: solve A0*X0 = B0
     *        | 1 |        | 10.5 |
     *   B0 = | 1 |,  X0 = | -2.5 |
     *        | 1 |        | -1.5 |
    //CUSOLVER_CHECK(cusolverDnDpotrsBatched(cusolverH, uplo, m, nrhs, /* only support rhs = 1*/
        //d_Aarray, lda, d_Barray, ldb, d_infoArray, batchSize));
    cublasDgetrsBatched(handle, CUBLAS_OP_N, m, nrhs, d_Aarray, lda, NULL, d_Barray, ldb, d_infoArray, batchSize);
    CUDA_CHECK(cudaMemcpyAsync(infoArray.data(), d_infoArray, sizeof(int), cudaMemcpyDeviceToHost,
        stream));
    CUDA_CHECK(
        cudaMemcpyAsync(X0.data(), Barray[0], sizeof(double) * X0.size(), cudaMemcpyDeviceToHost, stream));
    std::printf("after potrsBatched: infoArray[0] = %d\n", infoArray[0]);
    if (0 > infoArray[0]) {
        std::printf("%d-th parameter is wrong \n", -infoArray[0]);
        exit(1);
    std::printf("X0 = (matlab base-1)\n");
    print_matrix(m, 1, X0.data(), ldb);
    /* free resources */
    CUDA_CHECK(cudaFree(d_Aarray));
    CUDA_CHECK(cudaFree(d_Barray));
    CUDA_CHECK(cudaFree(d_infoArray));
        CUDA_CHECK(cudaFree(Aarray[j]));
        CUDA_CHECK(cudaFree(Barray[j]));
    CUSOLVER_CHECK(cusolverDnDestroy(cusolverH));
    CUDA_CHECK(cudaStreamDestroy(stream));
    CUDA_CHECK(cudaDeviceReset());
    return EXIT_SUCCESS;
here is a full example of cublasSgetrsBatched. The conversion from S to D should be trivial. Your code as posted has a seg fault in it. That is associated with host code. If I were attempting to identify problems with it, the first thing I would do is identify the specific line of code that is causing a seg fault. The process to do that has nothing to do with CUDA, and could be a simple as a binary search using printf() statements.
I find the stupid mistake, I take these two info both in the device memory for granted. Thanks for answering my question.
