Segmentation fault using cublas<T>getrsBatched
I’ve modified the LU decomposition sample from the CUDA sample collection (here) to solve batched matrix equations, but run into a segmentation fault when calling cublasgetrsBatched. The code is, in its entirety:
#include <stdio.h>
#include <stdlib.h>
#include <cublas_v2.h>
#include <cuda_runtime.h>
template <typename T>
void check(T result, char const *const func, const char *const file,
           int const line) {
  if (result) {
    fprintf(stderr, "CUDA error at %s:%d code=%d(%s) \"%s\" \n", file, line,
            static_cast<unsigned int>(result), _cudaGetErrorEnum(result), func);
    exit(EXIT_FAILURE);
#define checkCudaErrors(val) check((val), #val, __FILE__, __LINE__)
static const char *_cudaGetErrorEnum(cudaError_t error) {
  return cudaGetErrorName(error);
// configurable parameters
// dimension of matrix
#define N 3
#define BATCH_SIZE 2
// use double precision data type
#define DOUBLE_PRECISION /* comment this to use single precision */
#ifdef DOUBLE_PRECISION
#define DATA_TYPE double
#else
#define DATA_TYPE float
#endif /* DOUBLE_PRCISION */
// wrapper around cublas<t>getrfBatched()
cublasStatus_t cublasXgetrfBatched(cublasHandle_t handle, int n,
                                   DATA_TYPE* const A[], int lda, int* P,
                                   int* info, int batchSize) {
  return cublasDgetrfBatched(handle, n, A, lda, P, info, batchSize);
#else
  return cublasSgetrfBatched(handle, n, A, lda, P, info, batchSize);
#endif
// wrapper around cublas<t>getrsBatched()
cublasStatus_t cublasXgetrsBatched(cublasHandle_t handle,
                                   cublasOperation_t trans, int n,
                                   int nrhs, DATA_TYPE* const A[x],
                                   int lda, const int* P, DATA_TYPE* B[],
                                   int ldb, int* info, int batchSize) {
  return cublasDgetrsBatched(handle, trans, n, nrhs, A, lda, P, B, ldb,
                             info, batchSize);
#else
  return cublasSgetrsBatched(handle, trans, n, nrhs, A, lda, P, B, ldb,
                             info, batchSize);
#endif
// wrapper around malloc
// clears the allocated memory to 0
// terminates the program if malloc fails
void* xmalloc(size_t size) {
  void* ptr = malloc(size);
  if (ptr == NULL) {
    printf("> ERROR: malloc for size %zu failed..\n", size);
    exit(EXIT_FAILURE);
  memset(ptr, 0, size);
  return ptr;
void initSetAMatrix(DATA_TYPE* mat, DATA_TYPE factor) {
  DATA_TYPE toSet[N*N] = {2, -1, 1, 1, 1, 2, 1, -1, 3}; // A matrix that has a solution for the given B
  for (int i = 0; i < N*N; i++) {
    mat[i] = toSet[i]*factor; // Scale each element by the factor and set it
void initSetBMatrix(DATA_TYPE* mat, DATA_TYPE factor) {
  DATA_TYPE toSet[N] = {2, 3, -10}; // B matrix that has a solution for the given A
  for (int i = 0; i < N; i++) {
// print column-major matrix
void printMatrix(DATA_TYPE* mat, int width, int height) {
  for (int i = 0; i < height; i++) {
    for (int j = 0; j < width; j++) {
      printf("%6.3f ", mat[(j * height) + i]);
    printf("\n");
  printf("\n");
int main(int argc, char** argv) {
  // cuBLAS variables
  cublasStatus_t status;
  cublasHandle_t handle;
  // host variables
  size_t AmatSize = N * N * sizeof(DATA_TYPE);
  size_t BmatSize = N * sizeof(DATA_TYPE);
  DATA_TYPE* h_AarrayInput;
  DATA_TYPE* h_Aptr_array[BATCH_SIZE];
  DATA_TYPE* h_BarrayInput;
  DATA_TYPE* h_BarrayOutput;
  DATA_TYPE* h_Bptr_array[BATCH_SIZE];
  // device variables
  DATA_TYPE* d_Aarray;
  DATA_TYPE** d_Aptr_array;
  DATA_TYPE* d_Barray;
  DATA_TYPE** d_Bptr_array;
  int* d_pivotArray;
  int* d_AinfoArray;
  int* d_BinfoArray;
  // initialize cuBLAS
  status = cublasCreate(&handle);
  if (status != CUBLAS_STATUS_SUCCESS) {
    printf("> ERROR: cuBLAS initialization failed\n");
    return (EXIT_FAILURE);
  printf("> Using DOUBLE precision...\n");
#else
  printf("> Using SINGLE precision...\n");
#endif
  // allocate memory for host variables
  h_AarrayInput = (DATA_TYPE*)xmalloc(BATCH_SIZE * AmatSize);
  h_BarrayInput = (DATA_TYPE*)xmalloc(BATCH_SIZE * BmatSize);
  h_BarrayOutput = (DATA_TYPE*)xmalloc(BATCH_SIZE * BmatSize);
  // allocate memory for device variables
  checkCudaErrors(cudaMalloc((void**)&d_Aarray, BATCH_SIZE * AmatSize));
  checkCudaErrors(cudaMalloc((void**)&d_Barray, BATCH_SIZE * BmatSize));
  checkCudaErrors(
      cudaMalloc((void**)&d_pivotArray, N * BATCH_SIZE * sizeof(int)));
  checkCudaErrors(cudaMalloc((void**)&d_AinfoArray, BATCH_SIZE * sizeof(int)));
  checkCudaErrors(cudaMalloc((void**)&d_BinfoArray, BATCH_SIZE * sizeof(int)));
  checkCudaErrors(
      cudaMalloc((void**)&d_Aptr_array, BATCH_SIZE * sizeof(DATA_TYPE*)));
  checkCudaErrors(
      cudaMalloc((void**)&d_Bptr_array, BATCH_SIZE * sizeof(DATA_TYPE*)));
  // fill matrix with random data
  printf("> Generating A matrices...\n");
  for (int i = 0; i < BATCH_SIZE; i++) {
    initSetAMatrix(h_AarrayInput + (i * N * N), (DATA_TYPE)(i+1)); // Create matrices scaled by factors 1, 2, ...
  printf("> First A matrix:\n");
  printMatrix(h_AarrayInput, N, N);
  printf("> Generating B matrices...\n");
    initSetBMatrix(h_BarrayInput + (i * N), (DATA_TYPE)(i+1)); // Create matrices scaled by factors 1, 2, ...
  printf("> First B matrix:\n");
  printMatrix(h_BarrayInput, 1, N);
  // copy data to device from host
  printf("> Copying data from host memory to GPU memory...\n");
  checkCudaErrors(cudaMemcpy(d_Aarray, h_AarrayInput, BATCH_SIZE * AmatSize,
                             cudaMemcpyHostToDevice));
  checkCudaErrors(cudaMemcpy(d_Barray, h_BarrayInput, BATCH_SIZE * BmatSize,
  // create pointer array for matrices
  for (int i = 0; i < BATCH_SIZE; i++) h_Aptr_array[i] = d_Aarray + (i * N * N);
  for (int i = 0; i < BATCH_SIZE; i++) h_Bptr_array[i] = d_Barray + (i * N);
  // copy pointer array to device memory
  checkCudaErrors(cudaMemcpy(d_Aptr_array, h_Aptr_array,
                             BATCH_SIZE * sizeof(DATA_TYPE*),
  checkCudaErrors(cudaMemcpy(d_Bptr_array, h_Bptr_array,
  // perform LU decomposition
  printf("> Performing LU decomposition...\n");
  status = cublasXgetrfBatched(handle, N, d_Aptr_array, N, d_pivotArray,
                               d_AinfoArray, BATCH_SIZE);
  printf("> Calculating X matrix...\n");
  status = cublasXgetrsBatched(handle, CUBLAS_OP_N, N, 1, d_Aptr_array, N,
                               d_pivotArray, d_Bptr_array, N, d_BinfoArray,
                               BATCH_SIZE);
  // copy data to host from device
  printf("> Copying data from GPU memory to host memory...\n");
  checkCudaErrors(cudaMemcpy(h_BarrayOutput, d_Barray, BATCH_SIZE * BmatSize,
                             cudaMemcpyDeviceToHost));
  printf("> First X matrix:\n");
  printMatrix(h_BarrayOutput, 1, N);
  // free device variables
  checkCudaErrors(cudaFree(d_Aptr_array));
  checkCudaErrors(cudaFree(d_Bptr_array));
  checkCudaErrors(cudaFree(d_AinfoArray));
  checkCudaErrors(cudaFree(d_BinfoArray));
  checkCudaErrors(cudaFree(d_pivotArray));
  checkCudaErrors(cudaFree(d_Aarray));
  checkCudaErrors(cudaFree(d_Barray));
  // free host variables
  if (h_BarrayOutput) free(h_BarrayOutput);
  if (h_AarrayInput) free(h_AarrayInput);
  if (h_BarrayInput) free(h_AarrayInput);
  // destroy cuBLAS handle
  status = cublasDestroy(handle);
    printf("> ERROR: cuBLAS uninitialization failed...\n");
  return (EXIT_SUCCESS);
cuda-gdb gives the following error:
Thread 1 "main.out" received signal SIGSEGV, Segmentation fault.
0x00007ffff180a46c in cublasDgetrsBatched () from /opt/cuda/lib64/libcublas.so.11
and the following backtrace:
#0  0x00007ffff180a46c in cublasDgetrsBatched () from /opt/cuda/lib64/libcublas.so.11
#1  0x000055555555bcb5 in cublasXgetrsBatched (handle=0x55555c7d6cc0, trans=CUBLAS_OP_N, n=3, nrhs=1,
    A=0x7fffbd820e00, lda=3, P=0x7fffbd820800, B=0x7fffbd821000, ldb=3, info=0x7fffbd820c00, batchSize=2)
    at workingRfrs.cu:56
#2  0x000055555555c443 in main (argc=1, argv=0x7fffffffe018) at workingRfrs.cu:229
The code is being compiled and run on Arch Linux with nvcc version 11.2.152 and with g++ version 10.2.0.
I’ve checked the output of cublas<T>getrfBatched (by checking the values with p ((@global double*)h_Aptr_array[0])[0]@9 in cuda-gdb, and the result ({2, -0.5, 0.5, 1, 1.5, 1, 1, -0.5, 3}) is the correct LU decomposition (manually separating L and U and multiplying them gives the original A, and the output itself is the same as the result from MATLAB) and the pivot array likewise appears to be in order ({1, 2, 3} for each matrix) so getrf seems to be working just fine.
The only new parameters introduced by getrs compared to getrf are trans, nrhs, Barray[] and ldb. nrhs and ldb appear correct in the backtrace above, trans follows every example of its usage I’ve seen online, and Barray[] is initialized in a completely analogous manner to Aarray[] but with different dimensions. I’ve checked its values with p ((@global double*)h_Bptr_array[0])[0]@3 in cuda-gdb, and everything appears correct, at least from the host pointer.
I’ve tried to check the device pointer arrays in cuda-gdb to make sure that they are correct, but I haven’t found a way to do that reliably; running p ((@global double*)d_Aptr_array)[0] at a breakpoint just before getrf is called returns 6.9533006922051251e-310, which clearly is not right, but seeing as getrf successfully calculates the LU decomposition, the pointer array should be correct, and I’ve probably got the command wrong.
Any help, either with the code or simply with checking the device pointer arrays in the debugger would be greatly appreciated!
If you review cublasgetrsBatched(), notice that the 9th parameter (info) is a single variable. Where getrfbatched takes an array. That should fix your issue.
Can’t believe I spent so much time on this without ever noticing… Thank you! The code runs as expected with the suggested fix :)
