cublasDgelsBatched help
I am using CUDA 6.5 with cublas and I have been trying to get the cublasDgelsBatched function to work. However, when I call it, all I get is a segmentation fault. cuda-gdb and cuda-memcheck are not helping me resolve the issue. I have a feeling that the issue has something to do with the array of pointers, but I can’t seem to figure it out. I have consulted other batched code posts here.
https://devtalk.nvidia.com/default/topic/767806/gpu-accelerated-libraries/matrix-inversion-with-cublassgetri/
https://devtalk.nvidia.com/default/topic/761729/gpu-accelerated-libraries/cublasdgetrfbatched-and-cublasdgetribatched/
http://stackoverflow.com/questions/22887167/cublas-incorrect-inversion-for-matrix-with-zero-pivot
But none of the code examples here seem to be successful. Could somebody provide me with example usage for this function? Here is the code I am attempting to use. ls_matrix->data and solutions->data are just of data type double*.
double* cuda_test_batched_ls(matrix* ls_matrix, matrix* solutions, int batch_size){
    double *A[] = {ls_matrix->data};
    double** A_d;
    gpu_error_check(cudaMalloc<double*>(&A_d, sizeof(A)));
    gpu_error_check(cudaMemcpy(A_d, A, sizeof(A), cudaMemcpyHostToDevice));
    double *C[] = {solutions->data};
    double** C_d;
    gpu_error_check(cudaMalloc<double*>(&C_d, sizeof(C)));
    gpu_error_check(cudaMemcpy(C_d, C, sizeof(C), cudaMemcpyHostToDevice));
    cublasStatus_t status;
    cublasHandle_t handle;
    int* cublas_error_info = 0;
    status = cublasCreate_v2(&handle);
    if (status != CUBLAS_STATUS_SUCCESS){
        puts(cublas_get_error_string(status));
    status = cublasDgelsBatched(handle, CUBLAS_OP_N, ls_matrix->rows, ls_matrix->columns, 1, A_d, 3, C_d, 3, cublas_error_info, NULL, 1);
    gpu_error_check(cudaMemcpy(C, C_d, sizeof(C), cudaMemcpyDeviceToHost));
    return C[0];
If you look in the link you provided:
[url]https://devtalk.nvidia.com/default/topic/761729/gpu-accelerated-libraries/cublasdgetrfbatched-and-cublasdgetribatched/[/url]
at the code I posted there, it demonstrates how to send an array of matrices to the device, for cublas. There are at least 2 cudaMemcpy operations, one of which is called from a loop. Your code to transfer matrices looks nothing like that. You might start by studying those examples more thoroughly.
