I’m getting internal operation failed from a call to cublasDgelsBatched. I’ve been able to determine the error is coming from a call to geqrSolve_batch_kernel, but haven’t been able to get any further. Any suggestions on how to figure out what’s going on?
amdavis
1
mnicely
2
It’s helpful to provide reproducers. You can also try using the logger functionality to retrieve more information.
amdavis
3
Here’s the code and logger output.
Build:
nvcc -o gelscu gels_cublas.cu -lcublas -lcurand -lcudart
Code:
gels_cublas.cu (2.5 KB)
Output:
gelscu.output.txt (1.9 KB)
Related topics
| cublasDgelsBatched help | 1 | 1355 | November 21, 2014 | |
| Internal debugger error occurred while attempting to launch cublas batched dgemm | 1 | 546 | March 12, 2018 | |
| Cublas_status_execution_failed | 2 | 10911 | February 23, 2021 | |
| cublas_cublasDgetrsBatched_problem | 4 | 1127 | October 6, 2022 | |
| Exception Error cublasSgetrsBatched while cublasSgetrfBatched has no issues (cuda12.8) | 0 | 85 | September 24, 2025 | |
| Call to cublasDgetrsBatched from a Fortran code fails | 2 | 84 | August 26, 2026 | |
| cublasDtrsmBatched giving error when to solve array linear systems | 0 | 543 | October 25, 2017 | |
| Segmentation fault : cublasDgetrfBatched and cublasDgetriBatched | 5 | 1960 | July 10, 2019 | |
| Segmentation fault using cublas<T>getrsBatched | 2 | 1917 | April 19, 2021 | |
| Find reason behind CUBLAS_STATUS_INTERNAL_ERROR | 1 | 895 | December 18, 2020 |
