cublas handle reuse
Reading [1], see that reuse of cublasHandle_t is a good practice but if I need to make multiple calls per thread will continue to be a good practice?
If create a handle outside of kernel how can reference it to kernel?
//~ nvcc -rdc=true -arch=sm_35 -o t123 t123.cu -lcublas -lcublas_device -lcudadevrt
//~ sudo optirun --no-xorg ./t123
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include <string.h>
#include <cublas_v2.h>
__global__ void kernel2(cublasHandle_t handle, double *x){
	double alpha = 2.0;
	double *ptrAlpha = α
	cublasDscal(handle, _size, ptrAlpha, x, 1); //don't work with handle
	cudaDeviceSynchronize();
	cublasHandle_t handle2;
	cublasStatus_t stat;
	stat = cublasCreate(&handle2);
	if(stat != CUBLAS_STATUS_SUCCESS){
		printf("CUBLAS initialization failed\n");
		return;
	cublasDscal(handle2, _size, ptrAlpha, x, 1); //work with handle2
	cublasDestroy(handle2);
int main(int argc, char **argv){
	cublasHandle_t handle;
	stat = cublasCreate(&handle);
		return EXIT_FAILURE;
	double *vetor = new double[_size], *vetorOut = new double[_size];
	assert(vetor);
	assert(vetorOut);
	for(int i=0; i<_size; i++){
		vetor[i] = (double)i;
	double *ptrvetor;
	cudaMalloc((void**) &ptrvetor, _size*sizeof(double));
	cudaMemcpy(ptrvetor, vetor, _size*sizeof(double), cudaMemcpyHostToDevice);
	kernel2<<<1, 1>>>(handle, ptrvetor);
	cudaMemcpy(vetorOut, ptrvetor, _size*sizeof(double), cudaMemcpyDeviceToHost);
	printf("%f\n", vetorOut[_size-1]);
	cudaFree(ptrvetor);
	delete [] vetor;
	vetor = NULL;
	delete [] vetorOut;
	vetorOut = NULL;
	cublasDestroy(handle);
	return 0;
[1]:http://stackoverflow.com/questions/20999382/should-we-reuse-the-cublashandle-t-across-different-calls
Yes, any handles that you need to use on the device should be created in device code.
Note the description of the cublasHandle_t:
[url]http://docs.nvidia.com/cuda/cublas/index.html#cublashandle_t[/url]
“The cublasHandle_t type is a pointer type to an opaque structure holding the cuBLAS library context.”
Since it is a pointer type, when you create it on the host you have effectively created a host pointer (i.e. a pointer that points to an opaque structure in host memory).
When you pass such a pointer by-value to the device via kernel parameters, only the pointer value gets copied, not what it points to. So it is invalid to attempt to use that pointer in device code.
If you want to preserve a handle from one kernel call to the next, you could use:
device cublasHandle_t my_cublas_handle;
If my_cublas_handle was declared outside of kernel1 and created in kernel1, the handle is same for all threads? (even resource for all or each have your own?)
multiple threads should not share the same CUBLAS handle:
[url]http://docs.nvidia.com/cuda/cublas/index.html#thread-safety2[/url]
