I’m building an application on an Ampere-GPU machine, and the application needs CUDA 10.1 running at the same time (can’t use the latest for now). I’m bumping into driver version incompatibilities, even after following the documentation where we “should” be able to make both run by setting the CUDA_FORCE_PTX_JIT=1 (NVIDIA Ampere GPU Architecture Compatibility Guide :: CUDA Toolkit Documentation). I have not been able to successful build the application locally or even with CI. Would anyone have some helpful advice?
Here’s what’s currently installed on my CI builds:
| NVIDIA-SMI 515.65.01 Driver Version: 515.65.01 CUDA Version: 11.7 |
| | | MIG M. |
| 0 NVIDIA A10G Off | 00000000:00:1E.0 Off | 0 |
| 0% 22C P0 58W / 300W | 0MiB / 23028MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Sun_Jul_28_19:07:16_PDT_2019
Cuda compilation tools, release 10.1, V10.1.243
CUDA Version 10.1.243
