$ sudo dpkg -i Downloads/cuda-repo-ubuntu1804_10.1.105-1_amd64.deb
$ sudo apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
$ sudo apt update
$ sudo apt install cuda
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-runtime-10-1 : Depends: cuda-drivers (>= 418.39) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
cuda : Depends: cuda-10-1 (>= 10.1.105) but it is not going to be installed
I’m facing this problem as well and tracked it down to DPKG crashing when it tries to compile the included 418 driver - it is specific to the shipped driver - if I use the driver off the site nividia-418-418, it compiles but CUDA fails to recognize it (are you freaking kidding?! Get your sh!t together nvidia - every cuda package has something seriously wrong with it.)
