Hi there,
I accidentally deleted the cuda repo in the /var/ directory of my host PC. I have a Jetson TX2 and would like to update it to Ubuntu 18 using NVIDIAs SDKManager. For this I set my Jetson into recovery mode. However, before i started the update procedure, I installed some system updates in my host PC. Unfortunately, then my host PC wouldn’t want to boot anymore as my root directory “/” was 100% full. I saw that the cuda repository in /var/ was pretty big so I deleted it, assuming that the SDKManager will be able to install it there again.
Since this is not the case, I cannot update my Jetson as I would like to install CUDA on it too. The installation of CUDA fails with this message:
ERROR: CUDA on Host: [error]: key file [/var/cuda-repo-10-2-local-10.2.89-440.40/7fa2af80.pub] not found; [error]: stat /var/cuda-repo-10-2-local-10.2.89-440.40/7fa2af80.pub: no such file or directory; [deb_path]: /home/evitado/Downloads/nvidia/sdkm-downloads/cuda-repo-ubuntu1804-10-2-local-10.2.89-440.40_1.0-1_amd64.deb
16:35:36 ERROR: CUDA on Host: command terminated with error
16:35:36 SUMMARY: CUDA on Host: First Error: Failed to run apt-key add command [host]
As this error message suggests, I need to install the local repository into /var/ again. I tried to install the latest CUDA version (11.2) but installing the Jetson Jetpack fails as it requires the CUDA 10.2 repository in /var/. However, in the CUDA archive, the webpage for CUDA 10.2 does not offer any download buttons. Are there alternative download links?
Any help is appreciated!
Max
