Im currently developing under Mac OSX 10.9.2.
Cuda 6.0 supports Clang as a compiler. Clang uses libc++ as the default STL library by default.
There are two implementations of the standard C++ library available on OS X: libstdc++ and libc++. On 10.8 and earlier libstdc++ is chosen by default, on 10.9 libc++ is chosen by default.
The big issue I currently have is:
Cuda 6.0 is linked against libstdc++. Which means it can’t be used against code that uses libc++. So Im forced to use libstdc++, and cant use C++11 in my host code at the moment…
Are there any workarounds for this issue? Are there plans that Cuda compiles against libc++ in the near feature?
Thanks,
Gerald
