When will CUDA support libc++ on Mavericks?
I am aware of the fact that the latest CUDA (6.0) does not yet support libc++ on Mac OS X Mavericks. However, since libc++ has become the default when installing new libraries (through, say, MacPorts), I am wondering if CUDA will be able to support libc++ in the near future (maybe in 6.5?) Thank you.
I agree.
Qt5 compile with libc++. So right now it’s more or less not possible to compile with Qt 5 and CUDA easily…
Seems the issue is not resolved with Cuda 6.5 unfortunately.
Nvidia developers, we have to maintain a Qt4 backward compatibility just for that, and it’s really slow it down. And we’re certainly not the only one, first google search leads to this page : OSX 10.9 and CUDA 6? (answer = yes, supported) · Issue #405 · BVLC/caffe · GitHub
So please consider this as a high priority !
I am using CUDA 6.0 on OS X 10.9 together with Qt 5 (using libstdc++ for the CUDA part and libc++ for the Qt part). It is really unfortunate that this means I can not pass any objects containing STL stuff between CUDA code and the rest of the application.
Actually scrap that. I haven’t worked on the project in a while. It turns out I am using libstdc++ for the whole project, but a mix should still be possible.
See also:
https://devtalk.nvidia.com/default/topic/741707/cuda-setup-and-installation/cuda-6-mac-os-10-9-libstdc-still-required-/post/4217622/#4217622
https://devtalk.nvidia.com/default/topic/741707/cuda-setup-and-installation/cuda-6-mac-os-10-9-libstdc-still-required-/post/4292707/#4292707
The point remains. We need libc++ support. Even using libstdc++ for everything has issues (see first link above).
