I am using CUDA to accelerate a computationally-intensive Java application under Mac OS X 10.5. Java 6 delivers much, much better performance on the unaccelerated portions of the app than Java 5 - but it is 64-bit only under OS X, and there is only a 32-bit CUDA library available.
When will there be a 64-bit version of CUDA available for OS X? It would be nice to have an actual date, or a statement like “This is planned for version 2.1 under OS X”, or “This will not happen for at least six months.” The only information I can find about this says “We’re thinking about it”.
Seems that everyone has desisted on asking for a 64bit CUDA version for Mac OS!! I’m running 10.6.2 in 64bit kernel mode, and MATLAB and a lot of other software work great.
Version 3.0.1 (beta) of CUDA driver installs but doesn’t seem to work.
Is there any plan to support 64bit in MacOS as well as all the other operating systems?
Would it, could it be possible that the development of a 64 bit version of CUDA drivers for OS X had to be put on hold until SL 10.6.3 was finished?
The Nvidia team updated the drivers for that build and developing CUDA drivers might have been be put off until that higher priority task was finished.
I believe 64-bit CUDA runtime is working already in CUDA 3.1. (It appeared to work for me when I briefly tried it.) You have to pass the -m64 option to nvcc to get it to generate 64-bit host code, as it continues to emit 32-bit code by default.
