Hi
will there be x86_64 support in CUDA MacOSX ? If so, when will it be available?
The reason for asking is that if I call CUDA on MacOSX from Java and want to use
the latest JDK (1.6) which is currently only out (in preview) for the 64bit platform,
then a x86_64 bit version of CUDA is the only thing I can use (or go back to 1.5).
That also leaves the last question, will there be support for Java (or do I better build that
myself).
Regards
Mark Donszelmann
