Cuda 8.0 32-bit cross compilation
I want to compile my 32 bit code on 64 bit machine. So I am using -m32 flag with nvcc. But while linking cuda libraries, the compiler gives the following error :
skipping incompatible /usr/local/cuda-8.0/targets/x86_64-linux/lib//libcudadevrt.a when searching for -lcudadevrt
The reason why I am compiling with m32 flag is that I am using an external 32 bit library whose source code is not available.
So is there any way I can compile my cuda based 32 bit code on 64 bit machine.
I am using cuda 8.0 on linux machine.
