It is rather easy to build 32bit code on a 64bit Win Visual Studio 2010 machine.
Build-> configuration manager-> active solution platform-> x64 or win32
In Linux you need
sudo apt-get install gcc-multilib g+±multilib
Build the shared “stuff”:
@ ~/NVIDIA_GPU_Computing_SDK/C/
make i386=1 // will build 32 code
make x86_64=1 // will build 64 code
If they didn’tall build already, you can build the individual code samples by going into the project folder and using the correct MAKE commands.
If you get: /usr/bin/ld: cannot find -lshrutil_i386, you didn’t build the shared “stuff”. They appear in ~/NVIDIA_GPU_Computing_SDK/shared/lib.
You will more than likely get other shared lib errors, like /usr/bin/ld: cannot find -lglut. I’m not sure which libs to pull in to fix these.
When trying to run the 32bit code on a 64bit machine, you will get -> CUDA driver version is insufficient for CUDA runtime version.
The 64bit code should run fine.
