using 32bit nvidia opencl using 64bit system
if you like to use the 32bit version using a 64bit system, you can try this guide.
you can download the patch here: http://home.in.tum.de/~schreibm/opencl/patch_32on64.patch
this solution works using ubuntu jaunty using the driver NVIDIA-Linux-x86_64-185.18.08-pkg2.run
  1. first, install necessary 32bit libs (maybe i forgot some):
[font=“Courier New”]martin@vanadium:/usr/lib32$ sudo aptitude install lib32stdc++6 lib32gcc1 libc6-dev-i386[/font]
  1. on my ubuntu system, it was necessary to create a symlink for the 32bit version of libstdc++
[font=“Courier New”]martin@vanadium:/usr/lib32$ sudo ln libstdc++.so.6.0.10 ./libstdc++.so -s[/font]
  1. then you can install, patch and run the example programs:
[codebox]
[… install sdl using default installation options …]
martin@vanadium:~/NVIDIA_GPU_Computing_SDK$ patch -p1 < …/patch_32on64.patch
martin@vanadium:~/NVIDIA_GPU_Computing_SDK$ cd OpenCL/
martin@vanadium:~/NVIDIA_GPU_Computing_SDK/OpenCL$ make force32on64=1
martin@vanadium:~/NVIDIA_GPU_Computing_SDK/OpenCL$ make runall[/codebox]
good luck!
