Hallo @ all
I will compile the template example with a Microsoft 64bit compiler.
Here are my system informations:
Windows 7 64Bit
Microsoft SDK 7.1 with 64 bit compiler
Visual Studio Express 2010
NVIDIA 64bit cuda driver 270.81
CUDA Toolkit 64bit
CUDA SDK 64bit
I open the CUDA SDK Template with Visual Studio Express 2010. Then I change from Debug to Release und change to 64bit. After that I compiled the Template example project. But I get the following error:
3> C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK 4.0\C\src\template>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\bin\nvcc.exe” -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64” -I"./" -I"…/…/common/inc" -I"…/…/…/shared/inc" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\include" --keep-dir “x64\Release” -maxrregcount=0 --machine 64 --compile -Xcompiler "/EHsc /nologo /Od /Zi /MT " -o “x64/Release/template.cu.obj” “C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK 4.0\C\src\template\template.cu” -clean
3>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\BuildCustomizations<b>CUDA 4.0.targets(441,9): error MSB3721: Der Befehl ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\bin\nvcc.exe” -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64” -I”./" -I"…/…/common/inc" -I"…/…/…/shared/inc" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\include" --keep-dir “x64\Release” -maxrregcount=0 --machine 64 --compile -Xcompiler “/EHsc /nologo /Od /Zi /MT " -o “x64/Release/template.cu.obj” “C:\ProgramData\NVIDIA Corporation\NVIDIA GPU Computing SDK 4.0\C\src\template\template.cu” -clean” wurde mit Code -1 beendet.
========== Alles neu erstellen: 2 erfolgreich, Fehler bei 1, 0 übersprungen ==========
Can somebody compile the template project with visual studio express 2010 and 64bit conditions?
