I’m new to compiling CUDA samples, so forgive me if I miss something.
I am having the same issue as degreebeat. I have a GTX 1080 that is seemingly not working with CUDA 8.0 RC
CUDA 8.0 RC installation cannot find a compatible device.
I installed without the selected driver components and installed the latest driver (368.39 for Win10).
I’ve run the deviceQuery and deviceQueryDrv Samples. I tried to build the bandwidthTest Sample, however I get an error in MS Visual Studio 2015 that states: Microsoft Visual Studio 2015 Update >= 2 is not supported yet!
Here are the results from deviceQuery & deviceQueryDrv:
DEVICEQUERY:
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 3 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 8.0, CUDA Runtime Version = 8.0, NumDevs = 1, Device0 = GeForce GTX 1080
Result = PASS
Press any key to continue . . .
DEVICEQUERYDRV:
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v8.0\1_Utilities\deviceQueryDrv…/…/bin/win64/Debug/deviceQueryDrv.exe Starting…
CUDA Device Query (Driver API) statically linked version
Detected 1 CUDA Capable device(s)
Device 0: “GeForce GTX 1080”
CUDA Driver Version: 8.0
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 8192 MBytes (8589934592 bytes)
(20) Multiprocessors, (128) CUDA Cores/MP: 2560 CUDA Cores
GPU Max Clock rate: 1734 MHz (1.73 GHz)
Memory Clock rate: 5005 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Max Texture Dimension Sizes 1D=(131072) 2D=(131072, 65536) 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Warp size: 32
Concurrent kernel execution: Yes
Compute Mode:
Result = PASS
Thanks in advance for any help.
