Hi There!
Chat support told me to post this since they could not help.
Just bough a new Lenovo Y50 laptop with a GTX 960M graphics adapter. I have problems installing CUDA properly.
Symptoms:
- Windows 8.1 64 bit.
- Device manager shows two graphic adapters: NVidia GTX 960M and Intel HD Graphics 4600. Both running properly according to device manager.
- In “Manage 3D Settings” - global settings to use Nvidia performance processor (instead of auto-select).
- Did all windows updates.
- Installing GPU driver rev. 350.12 with no issues.
- When running the CUDA 7 installer it tells me that “This graphics driver could not find compatible graphics hardware. You may continue installation but you will not be able to run CUDA applications.”
- Running same installer on another laptop with GT 755M - installation recognizes graphics adapter with no problems.
- Chatting with CUDA chat support:
First supporter told me that I need to install visual studio first. Did that. Did not help.
Second supporter told me to install anyway and send him the report of two checks: DeviceQuery.exe and BandwidthTest.txt
Resutls below:
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v7.0\bin\win64\Debug>deviceQuery.
exe
deviceQuery.exe Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 960M"
CUDA Driver Version / Runtime Version 7.0 / 7.0
CUDA Capability Major/Minor version number: 5.0
Total amount of global memory: 4096 MBytes (4294967296 bytes)
( 5) Multiprocessors, (128) CUDA Cores/MP: 640 CUDA Cores
GPU Max Clock rate: 1176 MHz (1.18 GHz)
Memory Clock rate: 2505 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536),
3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Mo
del)
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simu
ltaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 7.0, CUDA Runtime Versi
on = 7.0, NumDevs = 1, Device0 = GeForce GTX 960M
Result = PASS
And
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v7.0\bin\win64\Debug>bandwidthTes
t.exe
[CUDA Bandwidth Test] - Starting...
Running on...
Device 0: GeForce GTX 960M
Quick Mode
Host to Device Bandwidth, 1 Device(s)
PINNED Memory Transfers
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 12346.6
Device to Host Bandwidth, 1 Device(s)
33554432 310303040.0
Device to Device Bandwidth, 1 Device(s)
33554432 67660.2
Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may v
ary when GPU Boost is enabled.
Any suggestions on how to solve this “compatible hardware not found” issue? Could this be that the graphics card is new and the CUDA installer does not include its VID/PID in its supported hardware list?
Suggestions please.
Thanks in advance.
