The installation of CUDA 9.2.88 proceeds without error, but, unlike 9.1, does not say anything about Visual Studio integration.
Opening the CUDA sample code Samples_vs2017.sln and attempting to build gives “unsupported Microsoft Visual Studio version” errors due to _MSC_VER being outside the range required by host_config.h. For VS2017 15.7.4, _MSC_VER is 1914, and host_config requires it to be in the range 1600-1913.
As suggested by previous posters, I have tried changing the test in host_config.h from
#if _MSC_VER < 1600 || _MSC_VER > 1913
to
#if _MSC_VER < 1600 || _MSC_VER > 1914
This allows me to compile the deviceQuery and some other samples (there are multiple copies of host_config.h, and I only modified one). Running deviceQuery gives the correct result.
QUESTION 1: Will CUDA 9.2 support VS 2017 15.7.4, or future minor updates of Visual Studio? Since Microsoft started changing the MSC_VER for every minor update, it breaks the hard-wired limit in host_config.h, while it seems unlikely that CUDA will fail to work due to the change in VS.
For an existing MFC/C++ project, I want to add my CUDA files (.cu) to the project. These worked with previous versions of CUDA and Visual Studio, but with the current versions, I cannot add the files. Project / Add existing item does not give any error, but it does not add the .cu files to the list of source files.
QUESTION 2: What else do I need to do to get CUDA properly integrated into VS2017, so I can compile, link and run a project comprised mainly of C++ code, with some CUDA device code?
CUDA 9.2.88; Visual Studio 2017 15.7.4; 64-bit Windows 7
