I am a beginner with Cuda, so I am trying to run an example.
But when I try to compile the cuda file, I have this error:
nvcc -c *.cu -I. -I/Developer/NVIDIA/CUDA-5.0/include/
In file included from /Developer/NVIDIA/CUDA-5.0/include/cuda_runtime.h:59:0,
from <command-line>:0:
/Developer/NVIDIA/CUDA-5.0/include/host_config.h:82:2: error: #error -- unsupported GNU version! gcc 4.7 and up are not supported!
kernel_code.cu:9:26: fatal error: cutil_inline.h: No such file or directory
compilation terminated.
It seems that gcc 4.7 and upper are not supported.
Is that normal?
If yes, what is the most recent version supported?
The CUDA toolkit usually is designed to work with whatever the standard compiler is for each supported Linux distribution. What Linux distribution are you using?
The problem could also be the use of CUDA 5.0 instead of CUDA 5.5. The release notes for CUDA 5.5 show support for gcc 4.7 on several common Linux platforms:
I don’t understand why I still work on Cuda 5.0, because yesterday I downloaded and installed the last version, but I don’t see any trace of Cuda 5.5 in my laptop :s
