I’ve been using cuda on linux for some time, and I’ve just gotten a new computer that comes with Windows Vista. I thought I would see if I can get cuda running. I do not have a copy of visual studio, and prefer to code in cygwin using xemacs as an editor.
However, now that I’ve installed the 2.0 beta driver, toolkit and sdk. I cannot compile. Here is the output I’m getting when I enter the command:
$ nvcc mc.cu -ccbin "c:\cygwin\bin"
nvcc fatal : nvcc cannot find a supported cl version. Only MSVC 7.1 and MSVC 8.0 are supported
I get the same error if I run this from the windows command prompt
c:\Program Files\NVIDIA Corporation\NVIDIA CUDA SDK\projects\MCGPU>nvcc mc.cu -ccbin c:\cygwin\bin\
So do have to use MSVC or is there another version of gcc I can use? Just need some clarity on the issue. Surely there is someone else who uses cygwin and gcc in order to compile their cuda code in Windows vista?
Regards,
Craig
