nvcc fatal : Compiler 'cl.exe' in PATH different than the one specified with -ccbin
I have Windows 10 x64, installed both Cuda 9.2 and 10.0 packages, latest updates. Visual Studio 2017, latest updates applied, latest SDK.
When I try and compile my cuda file, I get this error
1>D:\msradt\VideoAR_M2\camera_server\VideoARCamerasServer_2017>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin\nvcc.exe” -gencode=arch=compute_35,code="sm_35,compute_35" --use-local-env -ccbin “C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.16.27023\bin\Hostx64\x64\cl.exe” -x cu -ID:\msradt\VideoAR_M2\camera_server\External\Ximea\API -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include" -G --keep-dir x64\Debug -maxrregcount=0 --machine 64 --compile -cudart static -g -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_UNICODE -DUNICODE -Xcompiler "/EHsc /Wall /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\ColorSpace.cu.obj “D:\msradt\VideoAR_M2\camera_server\VideoARCamerasServer\Utils\ColorSpace.cu”
1>nvcc fatal : Compiler ‘cl.exe’ in PATH different than the one specified with -ccbin
when I look at cl’s path, I see this:
D:\msradt\VideoAR_M2>cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.16.27025.1 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
D:\msradt\VideoAR_M2>where cl
cl is same path as ccbin.
so… what gives, here? What’s the issue?
It needs to match what is in your windows environment PATH variable.
computer…properties…advanced system settings…Environment Variables
I’ve found few machines where NVCC fails to compile CUDA examples with
or simply errorlevel 1
Reason was in anaconda setting
HKEY_CURRENT_USER\Software\Microsoft\Command Processor\AutoRun
see
for explanation
