CUDA and OpenCV how to put them working together?
hi everybody,
i’m trying to do a simple thing, runing some OpenCV code on my CUDA (using cublas) project.
i’m just trying to compile the folowing lines (they are in the midle of CUBLAS code):
IplImage* img;
img=cvLoadImage( "./org.jpg",CV_LOAD_IMAGE_COLOR );
cvNamedWindow("Capture",CV_WINDOW_AUTOSIZE);
cvShowImage("Capture",img);
i have all the necessary includes in the file and my makefile looks like:
# Add source files here
EXECUTABLE	:= gpgpu
# Cuda source files (compiled with cudacc)
CUFILES		:= #gpgpu.cu
# C/C++ source files (compiled with gcc / c++)
CCFILES		:= \
	main.cpp \
	auxfunctions.cpp \
	#gpgpu_gold.cpp \
# Additional libraries needed by the project
USECUBLAS	   := 1
# Rules and targets
# for OpenCV's includes and libs, create path
NVCCFLAGS+=`pkg-config opencv --cflags`
	LIB+=`pkg-config opencv --libs`
include ../../common/common.mk
when i try to compile it gives the following error:
obj/release/main.cpp.o: In function `main':
main.cpp:(.text+0xa9): undefined reference to `cvLoadImage'
main.cpp:(.text+0xbf): undefined reference to `cvNamedWindow'
main.cpp:(.text+0xcf): undefined reference to `cvShowImage'
collect2: ld returned 1 exit status
make: *** [../../bin/linux/release/gpgpu] Error 1
i supose this is because the Opencv library’s are not linked correctly. i’v looked everywhere and i was’s able to find any decent topic about putting opencv and CUDA/CUBLAS working together.
I’d really apreciate any help. I’m running Ubuntu 8.04 on a 8800 GT.
thanks
Found a solution. it’s certainly not the way to do it but it works,
just modified the lines of common.mk from/to:
# Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc
to
# Includes
INCLUDES += -I. -I$(CUDA_INSTALL_PATH)/include -I$(COMMONDIR)/inc -I/usr/include/opencv
and
ifeq ($(USECUBLAS),1)
ifeq ($(emu),1)
LIB += -lcublasemu
else
LIB += -lcublas
endif
endif
to
ifeq ($(emu),1)
LIB += -lcublasemu -lcxcore -lcv -lhighgui -lcvaux -lml
else
LIB += -lcublas -lcxcore -lcv -lhighgui -lcvaux -lml
endif
endif
I am trying to run a simple open cv code using CUDA
The code is a sample program
#include<stdio.h>
#include<math.h>
include <cv.h>
include <highgui.h>
/This will pop up a small box with “Welcome to OpenCV” as the text.@author: Amir hossein khalili a_khalili@ce.sharif.eduimitated from Gavin Page, gsp8334@cs.rit.edu@date: 1 March 2007/
int main( int argc, char** argv )
{//declare for the height and width of the imageint
int height = 620;
int i=10;
int width = 440;//specify the point to place the text
CvPoint pt = cvPoint( height/4, width/2 );//Create an 8 bit, 3 plane image
IplImage* hw = cvCreateImage(cvSize(height, width), 8, 3);//Clearing the Image
cvSet(hw,cvScalar(0,0,0));//initialize the font
CvFont font;cvInitFont( &font, CV_FONT_HERSHEY_COMPLEX,1.0, 1.0, 0, 1, CV_AA);//place the text on the image using the font
cvPutText(hw, "Welcome To OpenCV", pt, &font, CV_RGB(150, 0, 150) );//create the window container
cvNamedWindow("Hello World", 0);//display the image in the container
cvShowImage("Hello World", hw);//hold the output windows
cvWaitKey(0);
return 0;
I have configured CUDA VS Wizard 2.2 (The Official NVIDIA Forums | NVIDIA) and it works perfectly to cmpile and run small cuda codes and also all the sample cuda codes. But when I build this code in a cpp file inside a cuda project created using the wizard installed in VS 2008, it says “unresolved external symbol” for all cv functions!! Another thing to wonder is when I only compile the cpp file containing this code in the cuda project it gets compiled successfully!
Another problem: If I make a cuda kernel (the file containing the kernel has definition to include cuda.h) and call it from within the cpp file, it says unable to open cuda.h!! But, when I only run a cuda code in this project it is able to find the cuda.h and gets executed.
Cuda file containing the cuda kernel:
include"cuda.h"
int cuda_kernel(int i)
i=i+10;
return(i);
While including this file in project I add these lines in the cpp file to check whether it is able to call cuda kernel or not:
int i = cuda_kernel(i);
printf(“%d”,i);
Also, I am unable to find the file common.mk in which change is needed to be done.
Please give some direction!!
Thanks in anticipation!
External Media
