CUDA BY EXAMPLE examples don't work
I’m trying to compile the CUDA BY EXAMPLE examples but cannot make it run :S here’s the output of the compiler
BRabbit$ nvcc julia_gpu.cu In file included from ../common/cpu_bitmap.h:20,
                 from julia_gpu.cu:18:
../common/gl_helper.h:44:21: error: GL/glut.h: No such file or directory
../common/gl_helper.h:45:22: error: GL/glext.h: No such file or directory
../common/gl_helper.h:46:20: error: GL/glx.h: No such file or directory
Any ideas?
OS X has the OpenGL headers in a different place to the standard layout that code is written to expect. Rather than just GL/, headers are located in OpenGL/ and GLUT/. You will need to modify the preprocessor #include statements accordingly.
Hi thanks,
I change the #include statements but still the last one can’t be found
#include <GLUT/glut.h>
#include <OpenGL/glext.h>
#include <GL/glx.h>           //Didn't work
#include <GLUT/glx.h>      //the same
#include <OpenGL/glx.h>  // the same
is it that the last library doesn’t exist in Mac OS X?
the errors are the following:
Undefined symbols:
  "_glDrawPixels", referenced from:
      CPUBitmap::Draw()     in tmpxft_0000065a_00000000-12_julia_gpu.o
  "_glClear", referenced from:
  "_glutInit", referenced from:
      CPUBitmap::display_and_exit(void (*)(void*))in tmpxft_0000065a_00000000-12_julia_gpu.o
  "_glFlush", referenced from:
  "_glutMainLoop", referenced from:
  "_glutInitDisplayMode", referenced from:
  "_glutInitWindowSize", referenced from:
  "_glutCreateWindow", referenced from:
  "_glutDisplayFunc", referenced from:
  "_glClearColor", referenced from:
  "_glutKeyboardFunc", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
You need to link GLUT and OpenGL
nvcc julia_gpu.cu -Xlinker -framework,GLUT -Xlinker -framework,OpenGL
Thanks a lot. I’m trying to learn also OpenGL.
Why do we have to link GLUT and OpenGL at compile time in Mac OS X? is it the same in all other OS?
Yes.
I tried the same:
but I still have a little problem:
%nvcc julia_gpu.cu -Xlinker -framework,GLUT -Xlinker -framework,OpenGL
In file included from …/common/cpu_bitmap.h:20,
…/common/gl_helper.h:47:38: error: GLUT/glx.h: No such file or directory
…/common/gl_helper.h:48:37: error: OpenGL/glx.h: No such file or directory
Thank you very much in advance for your help.
Change the following lines in your gl_helper.
#else
/* On Linux, include the system’s copy of glut.h, glext.h, and glx.h */
#include <GL/glut.h>
#include <GL/glext.h>
#include <GL/glx.h>
#endif
To:
#else
#if defined(APPLE) || defined(MACOSX)
#else
#include <GL/glx.h>
#endif
It should work ( it works for me)
That’s great, Thank you so much! It works for me too! Perfect!
Actually in Mac OS X there’s no “glx.h” so just don’t use it mines work fine I use the following libraries:
#include <OpenGL/glu.h>
#include <OpenGL/gl.h>
Hello, sorry for bringing this back from so long ago but I have a mac too and I’m trying to make the changes so I can run the code as well and I’m not doing something right.
So I essentially followed mfatica’s directions and changed the specified lines in my glhelper but still it doesn’t compile. Do I also need to do something else?
I still get the error
“In file included from …/common/cpu_bitmap.h:20,
…/common/gl_helper.h:51:21: error: GL/glut.h: No such file or directory
…/common/gl_helper.h:52:22: error: GL/glext.h: No such file or directory
…/common/gl_helper.h:53:21: error: GL/glx.h: No such file or directory”
Any help? Thanks
Try this tar file, everything should work aside from GL Interoperability.
Untar the file and type make in the main directory.
Edit: the system rejected .tgz files, now posted as .tar
cuda_by_example_mac.tar (670 KB)
Thanks mfatica for responding, but which tar file? I don’t see one attached.
edit: just made my email public if it’s easier to email it to me. Thanks again.
I also get this error:
In file included from julia_gpu.cu:18:
In file included from ./…/common/cpu_bitmap.h:20:
./…/common/gl_helper.h:17:2: error: unterminated conditional directive
#ifndef GL_HELPER_H
fixed adding and ENDIF at the bottom of gl_helper.h.
However, after this you need to modify a line in julia_gpu.cu:
change
cuComplex( float a, float b ) : r(a), i(b) {}
to
device cuComplex( float a, float b ) : r(a), i(b) {}
(see http://study.marearts.com/2015/03/error-calling-host-functioncucomplexcuc.html)
Finally, compile like:
and run a.out.
