has anybody tried CUDA computing on Lenovo Ideapad S12?? If so, do you reccomend it??
I was thinking about starting CUDA programming on it since it will costs less than 400 Euros here in Italy and I was willing to buy a netbook.
I built a small HTPC with a ZOTAC ION motherboard. The one with the dual-core N330 and built-in power supply. Though I built this thing to experiment with home theater and DVR issues, I’ve started experimenting with CUDA programming too. In the real world I develop software for simulation and 3D real-time visualization, so I wondered what I could do on such a little platform as compared to the workstations I normally work with. For its size and low power consumption, the ION platform is rather amazing.
I have Point Of View 330 mini-ITX ION mother board, and it work well, the compilation is slower than on a i7, but the power consumption is very low (between 20 an 22Watt with 3 Hard disk).
The GPU is similar of an 9300M (with faster clocks).
Here’s the output of deviceQuery on an Ion system (an Acer Revo):
Device 0: "ION"
CUDA Driver Version: 2.30
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 268435456 bytes
Number of multiprocessors: 2
Number of cores: 16
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.10 GHz
Concurrent copy and execution: No
Run time limit on kernels: No
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
