Cuda_driver_36.4.4.tbz2 is not available
Hello.
I can’t download this fix for 36.5 Release:
Page is not available:
Could you please provide the right link for this fix?
I’m happy to help you with your question. However, I don’t see any information in the provided context that directly relates to the issue you’re experiencing with downloading a fix for the 365 Release.
That being said, I can try to provide some general guidance on how to troubleshoot the issue.
  1. Check the NVIDIA website: You can try checking the NVIDIA website for any updates or patches related to the 365 Release. You can search for the specific issue you’re experiencing or check the downloads section for any available updates.
  2. Verify the link: Make sure that the link you’re trying to access is correct and not broken. You can try copying and pasting the link into a new browser window or checking if the link is available on other websites.
  3. Check for alternative sources: If the link is not available, you can try searching for alternative sources that may have the same fix or update. You can also try checking with NVIDIA support or forums to see if anyone else has experienced the same issue.
  4. Contact NVIDIA support: If none of the above steps work, you can try contacting NVIDIA support directly for assistance. They may be able to provide you with the correct link or guide you through the process of downloading the fix.
In terms of comparing the Jetson Orin NX to other models, I don’t see any relevant information in the provided context that would be helpful in resolving this issue. However, I can provide some general information about the Jetson Orin NX.
The Jetson Orin NX is a high-performance AI computing module designed for edge AI applications. It features a powerful NVIDIA Ampere GPU, a quad-core ARM Cortex-A78 CPU, and up to 32GB of LPDDR5 memory. The module also supports a range of interfaces, including PCIe, USB, and Gigabit Ethernet.
In comparison to other Jetson models, the Orin NX offers improved performance and power efficiency, making it well-suited for demanding AI workloads. However, the specific features and capabilities of the Orin NX may vary depending on the application and use case.
I hope this information is helpful. If you have any further questions or concerns, please don’t hesitate to ask.
Thanks for reporting this.
The patch is for r36.4.4. Please find it in the link below instead:
For the r36.5 environment, the patch is already merged so you don’t need it anymore.
We will check with the internal team to update the page.
Thanks and sorry for the confusion.
Hi. Thank you for information.
