pkb
October 11, 2010, 6:00pm
1
Hi All,
I have following 2 cards installed on my workstation.
$ lspci | grep -i nvidia
03:00.0 VGA compatible controller: nVidia Corporation G98 [Quadro NVS 295] (rev a1)
04:00.0 VGA compatible controller: nVidia Corporation GF100 [Tesla C2050] (rev a3)
04:00.1 Audio device: nVidia Corporation GF100 High Definition Audio Controller (rev a1)
I have installed the cudatoolkit and NVIDIA_GPU_Computing_SDK.
However, when i try to test the installation by running devicequery. I get the following error.
~/NVIDIA_GPU_Computing_SDK/C/bin/linux/release$ ./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
NVIDIA: could not open the device file /dev/nvidia1 (No such file or directory).
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
FAILED
Press to Quit…
Could you please help me in this matter ?
thanks.
pkb
2
Hi All,
FAILED
Press to Quit…
thanks.
seibert
October 11, 2010, 11:55pm
3
The CUDA device files are not created unless you start X or you run the script on page 6 of the Getting Started Guide:
[url=“http://developer.download.nvidia.com/compute/cuda/3_2/docs/Getting_Started_Linux.pdf ”]http://developer.download.nvidia.com/compu...arted_Linux.pdf[/url]
Note that you need to recreate the files in /dev every boot, so you probably want the script in your startup routine.
seibert
4
[url=“CUDA Toolkit Documentation ”]http://developer.download.nvidia.com/compu...arted_Linux.pdf[/url]
