I am using two Tesla C2050 with Scientific Linux,
I succed to install devdriver_3.2_linux_64_260.19.26.run, and the cuda tookit cudatoolkit_3.2.16_linux_64_rhel5.5.run,
I solved the lib problems, I also was able to compile the codes in gpucomputingsdk_3.2.16_linux.run,
however, when I run the examples I got:
$./deviceQuery
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
If you are not running X11, then you will need to create the /dev/nv* entries for the driver. How to do this is described in the CUDA toolkit for Linux release notes.
Are you user [font=“Courier New”]bouhadef[/font]? If you want Cuda to work for other users as well, you’ll have to give everyody read&write access to the devices:
