Timo23
September 21, 2010, 10:03pm
1
I am trying to get a Tesla C2050 to work in a Dell Precision T7500 workstation. I have installed the newest developer driver
260.24 from the Cuda Developer Site together with the Cuda Toolkit 3.2.9 and the GPU computing code samples version 3.2 under Ubuntu 10.04.
Installing the driver and compiling the examples works fine. Also, the driver itself is running. However, when I call deviceQuery I receive the following error message:
[codebox]
NVIDIA: could not open the device file /dev/nvidia1 (Input/output error).
cudaGetDeviceCount FAILED CUDA Driver and Runtime version may be mismatched.
FAILED
[/codebox]
Correct symlinks in /dev are present:
[codebox]
crw-rw-rw- 1 root root 195, 0 2010-09-21 22:29 /dev/nvidia0
crw-rw-rw- 1 root root 195, 1 2010-09-21 22:29 /dev/nvidia1
crw-rw-rw- 1 root root 195, 255 2010-09-21 22:29 /dev/nvidiactl
[/codebox]
In /var/log/messages the following error message appears:
[codebox]
Sep 21 22:44:02 smlx14 kernel: [ 924.433774] NVRM: rm_init_adapter(1) failed
Sep 21 22:55:41 smlx14 kernel: [ 1621.947432] NVRM: RmInitAdapter failed! (0x26:0x48:1028)
[/codebox]
I would be grateful for any comments on this issue.
Best wishes
Timo
mancio
September 22, 2010, 7:09pm
2
[codebox]
FAILED
[/codebox]
[codebox]
[/codebox]
[codebox]
[/codebox]
Best wishes
Timo
Hi Timo,
I was experiencing the same error (with the driver 256.53 and cuda 3.2).
Tired of trying to install sdk.
I re-installed my old 3.0 and related sdk (I leaved the driver 256.53).
Now all works fine and deviceQuery gives me:
Device 0: “GeForce GTX 260M”
CUDA Driver Version: 3.10
CUDA Runtime Version: 3.0
So probabily before the 2nd installation, the version of the driver was smaller than
that of the cuda.
I suggest you to try to install a older version of cuda and sdk.
good luck
marco
mancio
3
[codebox]
FAILED
[/codebox]
[codebox]
[/codebox]
[codebox]
[/codebox]
Best wishes
Timo
Hi Timo,
that of the cuda.
good luck
marco
Timo23
September 22, 2010, 10:02pm
4
unfortunately going back to the 3.1 version of the Toolkit and SDK did not help. The error message still remains.
Best wishes
Timo
Timo23
5
Best wishes
Timo
kwall
September 24, 2010, 11:10pm
6
[snippage]
[codebox]
[/codebox]
Best wishes
Timo
Please attach the output of nvidia-bug-report.sh run as root on the affected system. In addition, please attach the output of “strace -o cuda-strace.log deviceQuery”.
kwall
7
[snippage]
[codebox]
[/codebox]
Best wishes
Timo
Timo23
September 27, 2010, 9:45am
8
The error is now fixed. It turned out that only one power cable was connected with the card. After connecting the second power cable everything is running fine.
Best wishes
Timo
Timo23
9
Best wishes
Timo
Timo23
10
Best wishes
Timo
