Cuda fortran error: copyout Memcpy FAILED: 700(an illegal memory access was encountered)
When I was trying to compute 1D stencil with cuda fortran(using share memory), I got a illegal memory error. I have checked the program for a long time, but can not find the error.
`module reverse_m
implicit none
integer, device :: n_d
contains
attributes(global) subroutine staticReverse(a, d)
real :: d(:), a(:), result
integer :: t, tr, t1, ra = 3, j
real, shared :: s(-ra+1:64 + ra)
!real, shared :: s(64 + 2*ra)
t = (blockIdx%x-1)*blockDim%x + threadIdx%x
!write(*,*) 't:', t, ra
if (t > ra .and. t < size(a) - ra) then
    t1 = threadIdx%x
    !write(*,*) 't:', t1, a(t)
    s(t1) = a(t)
    write(*,*) 's(t1)', t1, s(t1)
    if (t1 <= ra) then
            s(t1 - ra) = a(t - ra)
    endif
    if (t1 >= 64 - ra) then
            s(t1 + ra) = a(t + ra)
    endif
endif
call syncthreads()
    write(*,*) t,t1
    result = 0
    do j = -ra, ra
        result = result + s(t1 + j)
    enddo
    d(t) = result
    write(*,*) 'size(d):', size(d)
endif
end subroutine staticReverse
end module reverse_m
program sharedExample
use cudafor
use reverse_m
implicit none
integer, parameter :: n = 64, ra = 3
real :: a(n), r(n), d(n)
real, device :: d_a(n), d_d(n)
type(dim3) :: grid, tBlock
integer :: i, sizeInBytes, j
tBlock = dim3(64,1,1)
grid = dim3(1,1,1)
do i = 1, n
a(i) = i
enddo
do i = 1 + ra, n - ra
do j = -ra, ra
d(i) = d(i) + a(i - j)
enddo
enddo
sizeInBytes = sizeof(a(1))*tBlock%x
! run version with static shared memory
d_a = a
write(,) ‘Size(a):’, size(a)
call staticReverse<<<grid,tBlock>>>(d_a, d_d)
r = d_d
write(,) ‘Static case max error:’, maxval(abs(r-d))
if (maxval(abs(r-d)) .gt. 1.0e-7) then
write(,) “Test Failed”
else
write(,) “Test Passed”
endif
end program sharedExample
When I was trying to print ‘s’ in the kernel function, It print nothing. It is weird. Can you help me find the error? thank you!
Hi Xll,
The problem here is that “s” is an automatic so dynamically allocated. For this, you’d need to pass in the size of the shared memory as the third argument in the chevron. See the “Dynamic Shared Memory” section at: https://developer.nvidia.com/blog/using-shared-memory-cuda-fortran/
Though, the simpler solution here is to make “s” static by changing “ra” to be a parameter.
integer :: t, tr, t1, j
integer, parameter :: ra=3
With this change, your program will run to completion, albeit fails verification.
% nvfortran test.cuf
% a.out
 Size(a):           64
 s(t1)           33    33.00000
 s(t1)           34    34.00000
 s(t1)           35    35.00000
 s(t1)           36    36.00000
... cut ...
 size(d):           64
 size(d):           64
 Static case max error:    427.0000
 Test Failed
-Mat
