I understand from here and here that the CUDA and cuDNN are installed in the container when using docker images for Jetpack >= 5, which causes the large increase in image size when upgrading from l4t 32.x
My application uses an image based on nvcr.io/nvidia/l4t-pytorch:r35.1.0-pth1.11-py3, which appears in the Jetpack 5.0.2 section on the l4t-pytorch containers page
Every cuda-related jobs are run within containers, and my application seems to run fine when removing the cuda-related packages after the JetPack install (cuda-toolkit-x-y and libcudnn8). In this scenario, do I need to use Jetpack at all?
I could more simply use l4t 35.1 + nvidia container runtime instead of Jetpack, or are there other benefit to using Jetpack?
Hi @user12474, yes if your application is already compiled and ready-to-deploy, you could rebase against l4t-cuda:runtime which doesn’t have the full CUDA Toolkit/ect in it and is smaller in size. Typically one could use a multi-stage Dockerfile to copy their binaries over from the “build” container into the “deployment” container.
Thank you for you response @dusty_nv .
I still need pytorch at runtime so I don’t think I can change the base image that easily if I understood your suggestion correctly.
The original issue in my question is the double cuda installation (system + container), are there any benefits to installing Jetpack when deploying containerized applications on l4t 35.x ?
