I have been trying to install cuda toolkit on the l4t32.6.1 container (I’m making a docker image in jetson TX2). I tried several methods to install but it keeps getting errors. Can you provide the details on how to do this properly
You can try l4t-cuda container which already has CUDA preinstalled.
Does that have jetpack?
Im actually building a docker image in TX2 which is to be deployed on nano?
jetpack version I use is 4.6
this is the error i get when I try to install toolkit in the l4t 32.6.1 container"
E: Unable to locate package cuda-toolkit-10-2
Can you please tell me if you have a solution to this or not?
I’m really stuck
JetPack 4.6 is r32.6.1.
For Jetson 4, the container will mount CUDA-related libraries from the Jetson native.
So you will need to install CUDA on Jetson itself as well.
