Cuda is not installed properly in ngc docker image
On jetson xavier orin, I use docker image: nvcr.io/nvidia/deepstream:7.0-samples-multiarch
There is no command $ nvcc --version and no plugin like libcupti.so.12.
But docker image : nvcr.io/nvidia/deepstream:7.0-triton-multiarch run properly.
I use "docker run --runtime=nvidia " command when test.
• DeepStream Version
• TensorRT Version
I solved this problem just add docker run command
-v /usr/local/cuda-12.2:/usr/local/cuda-12.2
This is normal. 7.0-samples-multiarch are only used for deployment and lack development tool support.
Here is an explanation of their differences
