I’ve installed CUDA-capable NVidia driver, CUDA-tools and CUDA_SDK on my comp
deviceQuery from CUDA SDK shows this:
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce 8600 GT”
CUDA Driver Version: 2.30
CUDA Runtime Version: 2.30
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 4
Number of cores: 32
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.19 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
But when I try to run some code from CUDA SDK with CUDA kernels, I always receive this:
Runtime API error in file …, line…: no CUDA-capable device is available.
$ uname -a
Linux sweden 2.6.26-2-686 #1 SMP Sun Jun 21 04:57:38 UTC 2009 i686 GNU/Linux
$ nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2009 NVIDIA Corporation
Built on Thu_Jul__2_10:56:25_PDT_2009
Cuda compilation tools, release 2.3, V0.2.1221
$ gcc --version
gcc (Debian 4.3.3-3) 4.3.3
Copyright © 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
What I do wrong? Please help!
