I logged in to my Xavier NX using my windows machine using SSH. I was able to access everything. I tried running the Imagenet model which was working fine on the Jetson Xavier NX itself.
Hi @CodeX29, those warnings are unrelated which you can ignore. You won’t see the OpenGL video feed window over SSH because that only works when a display is directly attached to your Jetson, or you are using remote desktop like VNC.
Thanks a lot for the support and help,
Can you recommend a good Remote Desktop software that I can use to connect to my Jetson Xavier NX ?
I tried using VNC server and even though my Jetson was about a metre away from my PC, the VNC server output was lagging a lot.
My Internet looks good so I don’t think that’s an issue
