hallo,
i am a CUDA rookie and i try to reproduce the CudaExample from the CUDA_ProgrammingGuide_2.3 page 20.
but i get the Error “CXX0030” (expression not evaluatable) in the Line where i allocated the device memory ?
Can anyone help me? thanks
* MatrixMulti CUDA program.
#define BLOCK_SIZE 32
#define WIDTH BLOCK_SIZE
#define HEIGHT BLOCK_SIZE
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <cutil.h>
typedef struct {
int width;
int height;
float* elements;
} Matrix;
/* Init CUDA */
#if __DEVICE_EMULATION__
bool InitCUDA(void){return true;}
#else
bool InitCUDA(void)
int count = 0;
int i = 0;
cudaGetDeviceCount(&count);
if(count == 0) {
fprintf(stderr, "There is no device.\n");
return false;
for(i = 0; i < count; i++) {
cudaDeviceProp prop;
if(cudaGetDeviceProperties(&prop, i) == cudaSuccess) {
if(prop.major >= 1) {
break;
if(i == count) {
fprintf(stderr, "There is no device supporting CUDA.\n");
return false;
cudaSetDevice(i);
printf("CUDA initialized.\n");
return true;
#endif
// Allocates a matrix with random float entries.
void randomInit(float* data, int size)
for (int i = 0; i < size; ++i)
data[i] = rand() / (float)RAND_MAX;
//Kernel
//Matrix multiplication kernel called by MatMul()
__global__ void MatMulKernel(Matrix A, Matrix B, Matrix C)
// Each thread computes one element of C
// by accumulating results into Cvalue
float Cvalue = 0;
int row = blockIdx.y * blockDim.y + threadIdx.y;
int col = blockIdx.x * blockDim.x + threadIdx.x;
for (int e = 0; e < A.width; ++e)
Cvalue += A.elements[row * A.width + e]
* B.elements[e * B.width + col];
C.elements[row * C.width + col] = Cvalue;
// Matrix multiplication - Host code
// Matrix dimensions are assumed to be multiples of BLOCK_SIZE
void MatMul(const Matrix A, const Matrix B, Matrix C)
// Load A and B to device memory
Matrix d_A,d_B,d_C;
size_t size = A.width * A.height * sizeof(float);
d_A.width =A.width; d_A.height = A.width;
CUDA_SAFE_CALL(cudaMalloc((void**)&d_A.elements, size));
CUDA_SAFE_CALL(cudaMemcpy(d_A.elements,A.elements, size,
cudaMemcpyHostToDevice));
d_B.width = B.width; d_B.height = B.height;
CUDA_SAFE_CALL(cudaMalloc((void**)&d_B.elements, size));
CUDA_SAFE_CALL(cudaMemcpy(d_B.elements, B.elements, size,
// Allocate C in device memory
d_C.width = C.width; d_C.height = C.height;
size = C.width * C.height * sizeof(float);
CUDA_SAFE_CALL(cudaMalloc((void**)&d_C.elements, size));
// Invoke kernel
dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
dim3 dimGrid(B.width / dimBlock.x, A.height / dimBlock.y);
unsigned int timer = 0;
CUT_SAFE_CALL( cutCreateTimer( &timer));
CUT_SAFE_CALL( cutStartTimer( timer));
MatMulKernel<<<dimGrid, dimBlock>>>(d_A, d_B, d_C);
CUT_CHECK_ERROR("Kernel execution failed\n");
CUDA_SAFE_CALL( cudaThreadSynchronize() );
CUT_SAFE_CALL( cutStopTimer( timer));
printf("Processing time: %f (ms)\n", cutGetTimerValue( timer));
CUT_SAFE_CALL( cutDeleteTimer( timer));
// Read C from device memory
cudaMemcpy(C.elements, d_C.elements, size,cudaMemcpyDeviceToHost);
// Free device memory
cudaFree(d_A.elements);
cudaFree(d_B.elements);
cudaFree(d_C.elements);
/*MAIN */
int main(int argc, char* argv[])
if(!InitCUDA()) {
return 0;
// allocate host memory for matrices A and B
Matrix h_A,h_B,h_C;
h_A.width=WIDTH;
h_A.height=HEIGHT;
h_B.width=WIDTH;
h_B.height=HEIGHT;
h_C.width=WIDTH;
h_C.height=HEIGHT;
unsigned int size = WIDTH*HEIGHT;
unsigned int mem_size = sizeof(float) * size;
h_A.elements= (float*) malloc(mem_size);
h_B.elements= (float*) malloc(mem_size);
h_C.elements= (float*) malloc(mem_size);
// set seed for rand()
srand(2006);
// initialize host memory
randomInit(h_A.elements, size);
randomInit(h_B.elements, size);
//invoke MatMul
MatMul(h_A,h_B,h_C);
CUT_EXIT(argc, argv);
return 0;
