I am trying to calculate SHAP Values from a previously trained Random Forest. I am getting the following error:
MemoryError: std::bad_alloc: CUDA error at: /opt/anaconda3/envs/rapids-21.12/include/rmm/mr/device/cuda_memory_resource.hpp
The Code I am using is
import pickle
from cuml.explainer import KernelExplainer
import cupy as cp
filename = 'cuml_random_forest_model.sav'
cuml_model = pickle.load(open(filename, 'rb'))
arr_cupy_X_test = cp.load("arr_cupy_X_test.npy")
cu_explainer = KernelExplainer(model=cuml_model.predict,
data=arr_cupy_X_test.astype(cp.float32),
is_gpu_model=True)
cu_shap_values = cu_explainer.shap_values(arr_cupy_X_test)
I am using gpu_usage()
and torch.cuda.empty_cache()
to clear gpu memory. I have diminished the size of the test array arr_cupy_X_test down to 100, but still receiving the error.
Is there maybe another issue with the cuml kernel explainer?
Any suggestions welcome.
