CUDA memory management : new delete free
Tesla c2075 ,CUDA 6.5,CC 2.0
I using OOP approach to CUDA . I am creating objects using new operators , classes , functions , inheritance etc…
My problem is that my program is failing after few iterations , with cuda debugger i see followng problem with memory —> problem with DELETE operator
Memory Checker detected 288 access violations.
error =
gridid = 39
blockIdx = {0,2,0}
threadIdx = {96,0,0}
address = 0x500a5fa60
accessSize = 0
First I have kernel :
extern "C" __global__  void Simulate()
   GetIntersectionsFromList()
and device function :
__device__    void GetIntersectionsFromList()
   LinkedItem<GeometryObject> *aGeomObject = Geometries.getFirstItem();
   GeometryObject* obj = aGeomObject->Item ;
   Vector3D* outPoints = obj->intersect(r_in);
   Intersection* ints = new Intersection()
   ints->Add(outPoints);
   delete obj;
where Geometries is list defined as
LinkedList<GeometryObject> Geometries =  LinkedList<GeometryObject>();
and LinkedItem is defined as :
Template<typename T> class LinkedItem
     public:
        T   *Item;
        LinkedItem<T> *NextItem;
     public:
        __device__ LinkedItem()
    __device__ LinkedItem (T *item_in)
        Item = item_in;
        NextItem = NULL;
my problem is …
delete obj;
On Warps Info Page I have : ! Exception InvalidFree
obj is not null , obj has normal values , obj is accesible but delete is problem , when i am debugging. So I think that it should be problem why my application fails after few runs …some memory issue
ALSO :
the problem is only with objcets created inside while loop …strange… and free(…)
while (aGeomObject != NULL)
GeometryObject* obj = aGeomObject->Item;
            if (isnan(outPoints[0].x))
            else
              Intersection* ints = new Intersection();
                ints->setOrigin(&outPoints[0]);
                ints->setDirection(&outPoints[1]);
                ints->setMaterial( obj->getMaterial());
                       delete ints;
      aGeomObject = Geometries.getNextItem(aGeomObject);
    free(outPoints); // doesnt WORK
        free(obj);  // deosnt WORK
 free(aGeomObject);// WORKS
problem should be with objects I am creating from my linkedlists or with objects pointer which are not directly created using new …
cross posted here:
[url]http://stackoverflow.com/questions/29963747/cuda-delete-operator-memory-checker-detected-288-access-violations[/url]
yes but I hope here I will have more comfortable answer …
just had the debugger abort and break on a free, without a malloc, only after the 6th iteration, with MALLOC_CHECK_ set to 2
so, go figure…
i had the array pointer in a structure; the array became redundant; i removed the malloc, but forgot to remove the free, and the pointer entry in the structure
somewhere, something somehow forgot about this until the 6th iteration
skittish
