I get a DLL error when I run TensorFlow with this program.
Import tensorflow
import tensorflow as tf
Initialize two constants
x1 = tf.constant([1,2,3,4])
x2 = tf.constant([5,6,7,8])
Multiply
result = tf.multiply(x1, x2)
Print the result
print(result)
this is the log that comes out.
2020-06-03 11:41:32.741197: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cudart64_101.dll’; dlerror: cudart64_101.dll not found
2020-06-03 11:41:32.741507: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
2020-06-03 11:41:44.113847: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library nvcuda.dll
2020-06-03 11:41:44.156841: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1561] Found device 0 with properties:
pciBusID: 0000:01:00.0 name: GeForce RTX 2060 SUPER computeCapability: 7.5
coreClock: 1.65GHz coreCount: 34 deviceMemorySize: 8.00GiB deviceMemoryBandwidth: 417.29GiB/s
2020-06-03 11:41:44.157536: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1561] Found device 1 with properties:
pciBusID: 0000:03:00.0 name: GeForce GT 710 computeCapability: 3.5
coreClock: 0.954GHz coreCount: 1 deviceMemorySize: 1.00GiB deviceMemoryBandwidth: 18.66GiB/s
2020-06-03 11:41:44.158065: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cudart64_101.dll’; dlerror: cudart64_101.dll not found
2020-06-03 11:41:44.158390: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cublas64_10.dll’; dlerror: cublas64_10.dll not found
2020-06-03 11:41:44.158724: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cufft64_10.dll’; dlerror: cufft64_10.dll not found
2020-06-03 11:41:44.159050: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘curand64_10.dll’; dlerror: curand64_10.dll not found
2020-06-03 11:41:44.159380: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cusolver64_10.dll’; dlerror: cusolver64_10.dll not found
2020-06-03 11:41:44.159705: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cusparse64_10.dll’; dlerror: cusparse64_10.dll not found
2020-06-03 11:41:44.160051: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘cudnn64_7.dll’; dlerror: cudnn64_7.dll not found
2020-06-03 11:41:44.160229: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1598] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices…
2020-06-03 11:41:44.161364: I tensorflow/core/platform/cpu_feature_guard.cc:143] Your CPU supports instructions that this TensorFlow binary was not compiled to use: AVX2
2020-06-03 11:41:44.171528: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x1f9c5806bc0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-06-03 11:41:44.171816: I tensorflow/compiler/xla/service/service.cc:176] StreamExecutor device (0): Host, Default Version
2020-06-03 11:41:44.172097: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1102] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-06-03 11:41:44.172260: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1108]
can someone please help
