2021-06-18 04:54:31.214597: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cudart64_110.dll’; dlerror: cudart64_110.dll not found
2021-06-18 04:54:31.214910: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cublas64_11.dll’; dlerror: cublas64_11.dll not found
2021-06-18 04:54:31.215263: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cublasLt64_11.dll’; dlerror: cublasLt64_11.dll not found
2021-06-18 04:54:31.215569: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cufft64_10.dll’; dlerror: cufft64_10.dll not found
2021-06-18 04:54:31.215867: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘curand64_10.dll’; dlerror: curand64_10.dll not found
2021-06-18 04:54:31.216194: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cusolver64_11.dll’; dlerror: cusolver64_11.dll not found
2021-06-18 04:54:31.216551: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cusparse64_11.dll’; dlerror: cusparse64_11.dll not found
2021-06-18 04:54:31.216927: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library ‘cudnn64_8.dll’; dlerror: cudnn64_8.dll not found
2021-06-18 04:54:31.217120: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1766] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at 使用 pip 安装 TensorFlow for how to download and setup the required libraries for your platform.
Skipping registering GPU devices…
2021-06-18 04:54:31.217943: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX AVX2
You have either not installed CUDA correctly (and also cudnn) or you have installed the wrong version, for the TF binary you are trying to use.
