cuda .Net. LoadModule raise GASS.CUDA.CUDAException
Hi all!
I’m doing a program in C # using the technology Cuda. Net. My program compiles, and create a file mykernel.cubin using the following command line:
nvcc "C:\Users\alvahtin\Documents\Visual Studio 2008\Projects\TestCuda\TestCuda\mykernel.cu" --cubin --compiler-bindir="C:\Program Files\Microsoft Visual Studio 9.0\VC\bin"
But this module mykernel.cubin can not load. There is code, where the call LoadModule raise exception “GASS.CUDA.CUDAException”
cuda = new CUDA(0, true);
int[] array = Enumerable.Range(0, 4096).ToArray();
CUdeviceptr d_input = cuda.CopyHostToDevice(array);
/*FileStream Sr = new FileStream(Path.Combine(Environment.CurrentDirectory, "mykernel.cubin"), FileMode.Open);
byte[] module = new byte[Sr.Length];
Sr.Read(module, 0, module.Length);
cuda.LoadModule(module);*/ //I trying do else, but no results
CUmodule module = cuda.LoadModule(Path.Combine(Environment.CurrentDirectory, "mykernel.cubin"));//this is throw exception
CUfunction func = cuda.GetModuleFunction("test_func");
cuda.SetFunctionBlockShape(func, 512, 1, 1);
cuda.SetParameter(func, 0, (uint)d_input.Pointer);
cuda.SetParameter(func, IntPtr.Size, (uint)42);
cuda.SetParameterSize(func, (uint)(IntPtr.Size + sizeof(uint)));
cuda.Launch(func, array.Length / 512, 1);
cuda.CopyDeviceToHost(d_input, array);
cuda.Free(d_input);
foreach (var item in array)
Console.WriteLine(item);
catch (CUDAException ex)
Console.ForegroundColor = ConsoleColor.Red;
Console.WriteLine("CUDAException");
Console.WriteLine(ex.Message);
Console.ReadLine();
What could be the problem?
I found the solution my problem: The Official NVIDIA Forums | NVIDIA
command line of create a file mykernel.cubin must be following:
nvcc  "C:\Users\alvahtin\Documents\Visual Studio 2008\Projects\TestCuda\TestCuda\mykernel.cu" --cubin --compiler-bindir="C:\Program Files\Microsoft Visual Studio 9.0\VC\bin" -arch=sm_20
